MikhailModeratorGreat ))
MikhailModeratorUse any image hosting for upload screenshots. For example https://imgur.com/
MikhailModeratorPlease provide the screenshots.
The command was sent successfully
This means just sending to the Communicator service.
See what is written in the communication line log in Communicator at the moment right after you send a command. You can find logs in C:\SCADA\ScadaComm\Log
MikhailModeratorAlso you can end the tasks:
https://imgur.com/a/DzgSE8u
MikhailModeratorHe means the tray:
https://imgur.com/a/m667u3v
MikhailModeratorServer cannot start correctly, that’s why the web app doesn’t connect to it.
MikhailModeratorLine 523, column 56: error CS1501: Keine Überladung für die Methode ‘GetBit’ nimmt 1-Argumente an.
See the file C:\SCADA\ScadaServer\Log\CalcEngine.cs with the source codeOpen CalcEngine.cs and go to Line 523, column 56
Probably you inccorctly use GetBit function.
All the formulas from Administrator are included in CalcEngine.cs. You should fix the formula in Administrator.
MikhailModeratorAlso useful Manual Installation
You can fix any issue without reinstalling.
MikhailModeratorOK, thanks for the status.
MikhailModeratorSee the log of the Server
C:\SCADA\ScadaServer\Log\ScadaServerSvc.logand the log of the web app
C:\SCADA\ScadaWeb\log\ScadaWeb.log
MikhailModeratorOn step 3 I tried to open Communicator. Instead of seeing Communicator with the arrow button, I got the Scheme Editor.
Could you provide screenshots describe the things you did?
Seems, you do the right things.
Can you open Rapid SCADA from other computers within your network?
How do you connect from the outsite? Do you use dynamic DNS?
MikhailModeratorCan you play with it using Chrome feature?
1. Try switching off font style.
2. Try type different symbols manually.
3. Try enter this symbol somewhere else in the page.
What are the results?
MikhailModeratorAll content of scada_guide_3_en.pdf was moved to http://doc.rapidscada.net/content/en/
Just ask here about formulas.
