Forum Home › Forums › Installation Issues › General Configuration Sequence
- This topic has 22 replies, 3 voices, and was last updated 8 years, 5 months ago by
June 14, 2018 at 7:43 pm #3836
joeh6966
ParticipantYesterday I started on the list of 7 items on the General Configuration Sequence. http://doc.rapidscada.net/content/en/software-configuration/general-configuration.html I got through the first 2 steps successfully. On step 3 I tried to open Communicator. Instead of seeing Communicator with the arrow button, I got the Scheme Editor.
So, today I clicked on Communicator in my Windows 8.1 Apps list and got a message that it was already running. There is no evidence of that. So far, I am stymied.
I am trying to get Rapid Scada to do ONE job; record or log energy used as measured by a Sentron PAC3200 via ethernet Modbus TCP/IP.
Joe
June 14, 2018 at 8:13 pm #3837
manjey73ParticipantThe Server and Communicator are started in minimized mode, locate from the system tray
June 15, 2018 at 4:35 pm #3840
MikhailModeratorOn step 3 I tried to open Communicator. Instead of seeing Communicator with the arrow button, I got the Scheme Editor.
Could you provide screenshots describe the things you did?
June 15, 2018 at 9:16 pm #3844joeh6966
Participantmanjey73 mentioned the system tray. I don’t know if he/she meant the taskbar at the bottom of my Windows screen. If I have the Administrator program open, it shows up in the taskbar. Communicator doesn’t show up anywhere except to tell me that it is already running and the new instance will be deleted.
I looked at task manager yesterday and Communicator is running. But I don’t know how to get it to do what it is supposed to do, as I can’t open it.
To provide the screenshots I would need to uninstall Rapid Scada and re-install.
Maybe I should just go to step 4.June 16, 2018 at 5:35 pm #3851
MikhailModeratorHe means the tray:
https://imgur.com/a/m667u3vJune 16, 2018 at 5:36 pm #3852
MikhailModeratorAlso you can end the tasks:
https://imgur.com/a/DzgSE8uJune 16, 2018 at 5:59 pm #3854joeh6966
ParticipantThat area is called a Taskbar by Windows 8.1 when I right click on it. You call it a tray. However, it only shows one icon; the Administrator icon.
I uninstalled and reinstalled and got thru steps 1 & 2, but the same result. I can’t do step 3. I clicked on Communicator in the Apps window and nothing appeared. If I go to Task Manager, there are 3 SCADA processes running. However, I did not see the import arrow as shown in step 3.
I have a ship but cannot link it here.
June 17, 2018 at 10:57 am #3856
MikhailModeratorPlease provide the screenshots.
June 17, 2018 at 2:33 pm #3857joeh6966
ParticipantJune 17, 2018 at 4:11 pm #3860joeh6966
ParticipantPlease give posting screenshots instruction. I tried 2 ways and failed.
June 18, 2018 at 2:14 pm #3862
MikhailModeratorUse any image hosting for upload screenshots. For example https://imgur.com/
June 18, 2018 at 2:19 pm #3864joeh6966
ParticipantI’ll try again. I used Imgur yesterday and posted the link.
June 18, 2018 at 2:46 pm #3865joeh6966
ParticipantJune 18, 2018 at 2:47 pm #3866joeh6966
ParticipantAfter submitting this post was blank. When editing it does show the link.
This reply was modified 8 years, 5 months ago by
joeh6966.
June 19, 2018 at 7:58 pm #3875joeh6966
Participant -
