OPC Write value issue – Matrikon Simulation
Forum Home › Forums › Communicating with Devices › OPC › OPC Write value issue – Matrikon Simulation
  • #3845
    bencyau
    I am just using the Matrikon Simulation OPC Server for testing, and I can read all the values desired within RapidScada with no issue.
    Using MatrikonOPCExplorer I can set the “Bucket Bridge.Boolean” between 0 and 1.
    I configured RapidScada Communicator for the above channel as “write data” with a command number 1. Sending command from the Communicator “Commands” tab got “The command was sent successfully”. However, the value in the “Device Data” tab does not seem to change.
    Thanks for your help.
    #3853
    This means just sending to the Communicator service.
    See what is written in the communication line log in Communicator at the moment right after you send a command. You can find logs in C:\SCADA\ScadaComm\Log
    #3861
    bencyau
    OK. My mistake found after finding the message below in the line log file:
    2018-06-18 09:25:58 Command execution is disabled by the communication line parameters
    Turns out I missed checking the “Commands Enabled” box in the Communication Line Parameter tab.
    Problem solved, now I can write to the OPC server tags.
    #3863
    Great ))
    #4231
    mariodavid
    I’m using an OPC server to connect to a PLC plc s7-300. I did everything that is said above but the value in the “Device Data” tab does not seem to change.
    “2018-09-12 10:41:02 Device 81. Handle current data changing. Subscription: llenado.diesel
    Device 81. Process tag. Name: PLC1.Generic.sensor-nivel-bajo-tanque-prinicipal. Value: True. Quality: good
    2018-09-12 10:41:03 Device 81. Handle current data changing. Subscription: llenado.diesel
    Device 81. Process tag. Name: PLC1.Generic.sensor-nivel-bajo-tanque-prinicipal. Value: False. Quality: good
    2018-09-12 10:41:02 <CONTROL-PC><SYSTEM><ACT> The command is received from file: type=Standard, device=81, number=4”
    i want set the tag to true but
    immediately changes to false
    how can i do?
    • This reply was modified 8 years, 1 month ago by mariodavid.
    #4240
    I answered here.
