Viewing 15 posts - 4,576 through 4,590 (of 6,293 total)
  • in reply to: OPC write value issue-IBH opc server #4460
    Thank you for the screenshots. I will send you a special version of the OPC driver and we can check again and compare info from OPC analyzer.
    in reply to: OPC write value issue-IBH opc server #4454
    I will send you a test version of KpOpc.dll during the week 22-28 of October.
    in reply to: Usage of the popup #4452
    Thank you for the information about the solution.
    in reply to: OPC write value issue-IBH opc server #4451
    Is it possible to write with IOPCSyncIO::Write?
    I don’t think that this is possible.
    In the source code of KpOpc.dll driver I just use daServer.Write(new Opc.Da.ItemValue[] { itemVal }); and the library made by OPC Foundation choose lo-level method WriteVQT.
    I can try setting Quality field of the item being written.
    in reply to: Reading bits #4445
    In communicator I can see that the register is just bound to one input channel but I want to give it to 16 input registers. How this is possible?
    One input channel is bound to only 1 tag in Communicator. For further calculations, you need to use one input channel (real type) as a source and other input channels of calculated type. If you post a link to a screenshot of your input channels, it would be easier to find a mistake.
    in reply to: OPC write value issue-IBH opc server #4444
    Try switch to OPC DA 2 in Communicator and check what write command is used.
    I can set Quality in the driver, but before I do it, it’s better to hear an answer from the OPC server developer.
    in reply to: Reading bits #4441
    Could you provide an example?
    Note: formulas are calculated in order of input channel numbers.
    in reply to: Usage of the popup #4440
    Hi Ben,
    Probably the old scripts are cached by a browser. Clear the browser cache or press Ctrl+F5 in a scheme web page.
    in reply to: Remote commumicator #4431
    If you use remote Communicator, you need the only one Communicator application on a remote PC. Other Rapid SCADA apps should not be installed there.
    In other case, if you have 2 Rapid SCADA servers, you can use Rapid Gate module to transfer data.
    in reply to: Reading bits #4430
    For input channels bound to the same device, signals have to be unique. Anyway, only one channel is bound.
    To use value from a one Communicator tag in many channels use channels of calculated type for other channels except the 1st.
    in reply to: Modbus TCP – One Element value gives 4 Digital Inputs, #4428
    Good!
    For new questions, please create new topics.
    in reply to: Elastic Report Questions #4416
    How to automatically have the number of rows based on the number of parameters available for a specific column for Elastic Report (PDF)?
    Please explain.
    in reply to: Elastic Report Questions #4414
    How to insert page break in Elastic Report (PDF)?
    Where you’d like to insert page break?
    The features you asked require additional development and update of the plugin. The most complex thing is that you need minute data in the report. Currently, the report uses hourly data only due to performance reason.
    Could you provide a report example that you need?
    We can discuss technical requirements here.
    After we clarify all technical details, to get an offer contains the development cost, please write by email.
    in reply to: OPC write value issue-IBH opc server #4413
    Please ask Marc why he doesn’t take into account the QualitySpecified field?
    Mario, I’m interested in solving this issue. Let’s continue the dialog.
    in reply to: OPC write value issue-IBH opc server #4411
    5.5.3 version? I am using 5.5.2
    The OPC driver was not changed.
