Elastic Report Questions
Forum Home › Forums › Understanding the Software › Elastic Report Questions
  • #4395
    Boon Chang
    I have a few questions regarding Elastic Report:
    How to insert page break in Elastic Report (PDF)?
    How to change the margins of the page layout of Elastic Report (PDF)?
    How to change the page numbering from “1” to “Page 1 of 5” in Elastic Report (PDF)?
    How to remove the “Generated: “ row below the Heading of Elastic Report?
    How to get the user name of the current user using the Webstation, and then have it printed in the Elastic Report?
    How to automatically have the number of rows based on the number of parameters available for a specific column for Elastic Report (PDF)?
    I require to set specific time period, precision up to the minutes (for example, 10/08/18 14:00 hours to 17/08/18 15:35 hours), for generating of Elastic Report. Do I send an email to request for an update of Elastic Report? (Referring to forum topic: https://forum.rapidscada.org/?topic=elastic-report-flexibility)
    #4414
    Where you’d like to insert page break?
    The features you asked require additional development and update of the plugin. The most complex thing is that you need minute data in the report. Currently, the report uses hourly data only due to performance reason.
    Could you provide a report example that you need?
    We can discuss technical requirements here.
    After we clarify all technical details, to get an offer contains the development cost, please write by email.
    #4416
    Please explain.
