Viewing 15 posts - 4,351 through 4,365 (of 6,296 total)
  • in reply to: MAP tile server #5062
    I mean, do you need powerful machine for maintain real map server?
    in reply to: Cannot add new components in ScadaWeb #5061
    Please clarify your question.
    in reply to: Chart Pro Select Time Period & Exporting data #5060
    1) This function is not available because nobody wants to sponsor it.
    2) No. I’m not sure that such report has a good and clear layout, because there are a lot of data points which are scrolled on a screen.
    in reply to: Applikon Bioreactor #5059
    What communication protocols are supported by the controller?
    If you try using OPC, these manuals can help:
    Article
    Video
    in reply to: Can I get data from communicatior directly? #5052
    Definitely, your diagram is correct.
    If the system is not big, I suggest to deploy the same configuration database for all local computers and the remote computer to make configuring easier.
    in reply to: ModDBExport #5051
    An INSERT statement executes for each channel separately.
    That’s why the default expression is simple
    INSERT INTO CnlData (DateTime, CnlNum, Val, Stat)
    VALUES (@dateTime, @cnlNum, @val, @stat)
    You have to change it to executing a stored procedure. Example for Postgres
    SELECT my_schema.proc_cur_data(@cnlNum, @val, @stat);
    And then perform filtering in the stored procedure my_schema.proc_cur_data.
    in reply to: MAP tile server #5050
    Good!
    Is it heavy?
    in reply to: Cannot add new components in ScadaWeb #5049
    ScadaWeb includes many folders after build. ScadaWebShell5 is the main part.
    For web applications, you should perform Publish in VS.
    in reply to: Modbus input channel scaling #5048
    in reply to: Modbus input channel scaling #5047
    Open Administrator, find the appropriate input channel and set its formula, for example, Cnl/10
    in reply to: Install software after building #5046
    See the structure of the distributive package and this article.
    in reply to: ModDBExport #5038
    but how to doit?
    See T-SQL manual. Also we can develop scripts for you for a fee.
    in reply to: Cannot add new components in ScadaWeb #5037
    I suppose, first, you should install Rapid SCADA from distributive. When it works correctly, compare the installed files with results of your own build.
    in reply to: Can I get data from communicatior directly? #5036
    You have several options:
    1. Deploy 2 instances of Rapid SCADA (local and remote) and connect them using Rapid Gate module.
    2. Get data from a remote computer by the web application.
    I have to get the data from the sever.
    That’s true.
    in reply to: ModDBExport #5030
    What database do you use? (MS SQL, MySQL, etc.)
    I suppose, you should specify a stored procedure where to filter channels. And use this stored procedure in the export module.
