Can I get data from communicatior directly?
Forum Home Forums Communicating with Devices Can I get data from communicatior directly?
This topic contains 4 replies, has 2 voices, and was last updated by  wcflcl 3 weeks, 2 days ago.
  • #5035
    wcflcl
    In my system, the communicatior is setuped on the local computer, and the sever is setuped on the remote computer.
    I need to display the data of devices on the local computer.But it seems ,I have to get the data from the sever.
    Can I get the data from communicatior directly?
    Thanks!
    #5036
    You have several options:
    1. Deploy 2 instances of Rapid SCADA (local and remote) and connect them using Rapid Gate module.
    2. Get data from a remote computer by the web application.
    That’s true.
    #5040
    wcflcl
    Thank you very much!But I have some questions:
    1.Rapid Gate
    If I have three devices in different places.I have to install communicatior,
    sever and rapid gate on the local computer which connects the device in every places.And I also have to install a sever on the remote computer.
    Then I can get data of all devices from the sever on the remote computer?
    get data with rapid gate
    2.The efficiency of the scheme does not meet my application requirements.
    #5052
    Definitely, your diagram is correct.
    If the system is not big, I suggest to deploy the same configuration database for all local computers and the remote computer to make configuring easier.
    #5068
    wcflcl
    I think that the Rapid Gate module can meet my requirements,and I will try it in my application .
