Viewing 15 posts - 406 through 420 (of 6,282 total)
  • in reply to: Execute weblink in channel table #16856
    In the Scripts table add
    public double StartProcess()
      Process.Start(@"/opt/scada/myscript.ssh");
      return 1.0;
    and create myscript.ssh containing the necessary commands.
    Then use that function in the output formula.
    in reply to: UTC date and time #16855
    The time seems to be converted from UTC to local time, so in order to become UTC in the view, I would have to convert it additionally.
    That’s right. Probably, we need to add an additional option to control displaying.
    in reply to: Execute weblink in channel table #16849
    To shut down a Linux machine it’s better to connect by SSH and execute a shell command.
    in reply to: Execute weblink in channel table #16848
    You can create a channel with an output formula that executes an external script to shutdown the machine.
    But it’s not a good practice.
    in reply to: scheme views showing blank #16846
    Open the folder SCADA\ScadaWeb\wwwroot\plugins\Scheme\js in the file explorer and check if those files exist.
    If they don’t exist, copy the files from the installation package.
    • This reply was modified 10 months ago by Mikhail.
    in reply to: scheme views showing blank #16839
    Could you provide a screenshot of the error? I need a path of the missed file.
    > and scheme’s display on another computer
    Do you mean that it works when a client opens a scheme remotely hosted on the same server? Or another installation?
    in reply to: DB Import string #16838
    Currently long strings are not supported by the DrvDbImport drvier. I hope, we will implement it in the future.
    If the strings have fixed values, they can be presented as numbers, and enumerations can be used.
    Alternatively, use the community driver noticed above.
    in reply to: Execute weblink in channel table #16837
    Scripts are executed on server side, so they have no connection with a web browser.
    How is the information expected to be presented to the end user?
    in reply to: Logs #16836
    If I set this to “Channel Status Has Changed”, some event would possible get logged when the Status changes to 1 which I can later review.
    Try “Channel Data Has Changed” or “Channel Status Has Changed”. Play with it.
    in reply to: scheme views showing blank #16824
    Press F12 to open browser tools. In the Console tab there are additional info about scheme loading.
    in reply to: Logs #16823
    May be you could setup generating events for those channels to control when they change.
    in reply to: Logging fast I/O #16822
    Seems, that a good approach would be to change a communication protocol. It would be more efficient to receive bunch of data that contains many data points.
    in reply to: Chart component fixed mode period #16816
    In Chart and Chart Pro plugins, the X axis is always time, Y axis is value.
    in reply to: Logs #16815
    The module writes to its own log file.
    Open Administrator – Instances – Default – Server – Logs, then set the log filter to modules.
    Other explanation is that I’ve written too many code in JavaScript recently, so I messed up C# and JavaScript 🙂
