Could you provide content of Communication Line Log page?
MikhailModeratorThis is a bad practice, because records still duplicated, but without error.
Somewhere in this forum or https://forum.rapidscada.ru/, a solution how to skip inserting duplicated records.
MikhailModeratorNow all the articles of http://doc.rapidscada.net/content/latest/en/ are updated for the version 5.7.
Click the left mouse button and hold it. Move mouse to the right. Release the mouse button.
Seems like version mismatch.
Please write here the version of Webstation and the version of Chart Pro and Dashboard.You can check the versions by yourself at http://doc.rapidscada.net/content/latest/en/version-history/
(release dates of the application and the plugins should be close)
In Webstation, click Main Menu > Reports and you will see it.
http://demo.rapidscada.net/Reports.aspx
MikhailModeratorDid you download 5.7.0?
Please provide more information how to reproduce to problem related to events. What plugin raises the error?
Please provide a screenshot.
MikhailModeratorI’ve just checked, the files are available. Strange.
I suggest Rapid SCADA 5.7.0.
What version do you download?
Where do you from?
Please try to do it using another PC.
> Please where can we define event instructions?
Please ask particular questions on the forum, and we will explain how it works.> how can we add user comments when acknowledge an alarm
Currently, this feature is not implemented.
C:\SCADA\ScadaComm\Log also contains lineXXX.log.bak, where you can find the previous part of the log. But this is also a part of log, not full.
May be we should add the option to set the log file sizes.
MikhailModeratorPlease provide a screenshot with device settings for gmail.
I don’t think that timeout really make sense.July 7, 2019 at 7:15 am in reply to: Digital Counter and calculate elapsed time for a channel in certain state #5684
Other approach is creating your own formula (in the Formulas table) like this
public double CalcSwitch(int counterCnlNum) { if (Val() <= 0 && Cnl > 0 && CnlStat > 0) { SetVal(counterCnlNum, Val(counterCnlNum) + 1); } return Cnl; }Use this formula in the channel 114: CalcSwitch(115)
where 115 is the channel for counting, its type is Calculated real.
Note: I don’t test formulas on the forum. May be you need to fix it. -
