MQTT sending value not showing in the communicator
Forum Home › Forums › Uncategorized Issues › MQTT sending value not showing in the communicator
  • #5710
    vkp2808
    As suggested i configured the mqtt.
    I modified config file with my mqtt server setting and the subscription topic and the channel number.
    with the same channel number i created a input channel.
    pls find below screenshots.
    RapidScada Communicator Config: https://ibb.co/K54B1Pm
    Mqtt Config: https://ibb.co/cNd9n5t
    Device Config: https://ibb.co/WH2hs9w
    Input Channel: https://ibb.co/yF4M10v
    Communicator Line Status: https://ibb.co/d4pQ2vc
    Communicator Device status: https://ibb.co/HqJrc92
    I am unable to see the value in the communicator. pls suggest any.
    Thanks in advance
    #5715
    Could you provide content of Communication Line Log page?
    #5720
    vkp2808
    Hi Mikhail, thanks for your quick reply.
    i resolved the issue by restarting the sever.
    –Vinod
    #5725
    Thanks for noticing.
