Dashboard Application Error
Forum Home Forums Installation Issues Dashboard Application Error
This topic contains 6 replies, has 2 voices, and was last updated by Mikhail Mikhail 6 months, 1 week ago.
  • #5705
    Avatar
    Johannes
    Hello folks,
    today I tried using Dashboard Plugin with ChartPro with a trial license. If I want to open the Dashboard Example 1 I get Application Error:
    Application Error
    Details:
    Methode nicht gefunden: “System.String Scada.CommonPhrases.get_ProductName()”.
    Trying to open my own Dashboard I get the same error.
    Does anyone have an idea what is wrong?
    Thank you for your help!!
    #5711
    Seems like version mismatch.
    Please write here the version of Webstation and the version of Chart Pro and Dashboard.
    You can check the versions by yourself at http://doc.rapidscada.net/content/latest/en/version-history/
    (release dates of the application and the plugins should be close)
    #5719
    Avatar
    Johannes
    Webstation 5.0.8.0
    Dashboard 5.1.0.0
    ChartPro 5.0.3.1
    You would recommend an update to SCADA 5.7.0?
    #5724
    Dashboard 5.1.0.0 requires Webstation 5.0.9.0.
    Definitely.
    #5749
    Avatar
    Johannes
    i have update problems. Before rapid scada installation on Windows 7 i had to install .NET framework 4.8. runtime. Before installation of Scada i am not able to click some .net framework 4.8 options in windows features.
    In line log i get error establishing TCP connection: access denied.
    2019-07-25 12:32:29 Establish a TCP connection with 127.0.0.1:502
    Error establishing TCP connection: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte 127.0.0.1:502
    Can you help me?
    #5751
    Avatar
    Johannes
    it s okay now
    #5753
    it s okay now
    Thanks for noticing.
