Viewing communication log
Forum Home › Forums › Communicating with Devices › Modbus › Viewing communication log
  • #5687
    skk2019
    is there any way of checking the communication line log since the start of communication? I am communicating devices using Modbus. In the linexx.txt log in the ScadaComm/Log folder, I can find the log data for an hour or so before. I would like to review the data before that and would like to check the errors and the reasons for it. or basically, just any way to view the error log.
    Thanks in advance.
    #5689
    C:\SCADA\ScadaComm\Log also contains lineXXX.log.bak, where you can find the previous part of the log. But this is also a part of log, not full.
    May be we should add the option to set the log file sizes.
    #5690
    skk2019
    yes, adding that feature would really be helpful to check the errors. Right now I got errors during the night but when I want to check what caused those errors I have no log. Hence, the error logging feature will be really helpful.
    Thanks 🙂
    • This reply was modified 7 years, 4 months ago by skk2019.
