Viewing 15 posts - 3,976 through 3,990 (of 6,299 total)
  • in reply to: Output control by Input #6111
    Is this the same physical device or 2 different devices?
    You should check communication line log in Communicator and find the lines when you send a command.
    in reply to: Events trigger and colors #6099
    If the above message contains a question, please do the following:
    1. Make screenshots of the settings you already did.
    2. Describe the actual behavior.
    3. Describe the needed behavior.
    in reply to: Use of the buttons #6098
    You can set a formula for an output channel the process the entered value. To create a complex formula, use the Formulas table.
    in reply to: Scheme Loading Failed after installing #6097
    This error means that WCF dowsn’t works. Please check whether the Windows features match the manual.
    in reply to: Chart Pro graph header #6095
    Custom header will be included in the next release of Chart Pro 5.0.4.0.
    in reply to: Installation problem RapidScada 5 #6083
    KpModbusSlave.dll is going to be developed on summer 2020. In case of using Modbus master, select KpModbus.dll.
    You can write to https://forum.rapidscada.ru/ if you prefer.
    in reply to: KNX Driver #6080
    Read this as an introduction.
    Then use the existing drivers as templates.
    in reply to: Get time from two channels #6079
    now I only have to eliminate the seconds.
    In this case it’s better to simply use 2 text components close to each other. And “:” between them.
    in reply to: Get time from two channels #6076
    To display:
    Create a 3rd input channel of the Calculated real type.
    Use a formula for this channel. Something like EncodeDate(new DateTime(1, 1, 1, Val(101), Val(102), 0))
    where 101 and 102 are the channels for hours and minutes.
    Set the format of the new channel to Time.
    When the above works, let’s think how to set the time.
    in reply to: Output command value #6075
    Cmd and CmdVal – the both are correct and mean the same.
    in reply to: Output command value #6070
    CmdVal * 1000 is a correct formula for an output channel. What is the issue with it?
    in reply to: Automatic Control Issue #6068
    I can’t download the zip, but I think it’s not necessary. Number of triggers doesn’t matter.
    Let’s choose a one of the following ways:
    1. Create as simple project as possible and find how to reproduce the problem without real devices. So I can do fix the bug on my PC.
    2. Remote trobleshooting as a paid service.
    in reply to: Automatic Control Issue #6065
    Nice screenshot. The configuration looks correct.
    Make sure that you sent configuration to the server, and SCADA-Server was restarted after configuration changed.
    Do other similar triggers work or not?
    Also check the channel 7239 status in the current data file.
    in reply to: channels support array type #6060
    How does it provide data? What communication protocol is used?
    in reply to: Automatic Control Issue #6059
    Please make a screenshot of your trigger settings. And provide ModAutoControl.log
