Installation problem RapidScada 5
Forum Home › Forums › Installation Issues › Installation problem RapidScada 5
  • #6019
    tommi.vahtera
    Hi
    Installation fail always .Net framework “error”.
    Trying to install latest RapidScada 5.7.1 to Windows10 Pro 32bit with latest updates.
    Installation gives notes and error:
    Rapid SCADA 5.7.1 Installation
    Install Server application
    Installation of Server application has completed with a error:
    Directory C:\SCADA\ScadaServer has to be cleared
    Directory C:\SCADA\ArchiveDAT has to be cleared
    Directory C:\SCADA\ArchiveDATCopy has to be cleared
    Directory C:\SCADA\BaseDAT has to be cleared
    Directory C:\SCADA\Interface has to be cleared
    Install Communicator application
    Installation of Communicator application has completed with a error:
    Directory C:\SCADA\ScadaComm has to be cleared
    Check the configuration of Internet Information Services (IIS)
    Go to
    Control Panel > Programs > Turn Windows features on or off
    and make sure that WCF Services > HTTP Activation feature is installed for .NET Framework 4+,
    whereas the components for .NET Framework 3.5 are switched off
    Check Windows Communication Foundation (WCF)
    Register ASP.NET
    Install Webstation application
    installation of Webstation application has completed with a error:
    Directory C:\SCADA\ScadaWeb has to be cleared
    Install Agent application
    Installation of Agent application has completed with a error:
    Directory C:\SCADA\ScadaAgent has to be cleared
    Installation of Administrator application has completed with a error:
    Directory C:\SCADA\ScadaAdmin has to be cleared
    Directory C:\SCADA\Projects has to be cleared
    Install Scheme Editor application
    Installation of Scheme Editor application has completed with a error:
    Directory C:\SCADA\ScadaSchemeEditor has to be cleared
    Install Table Editor application
    Installation of Table Editor application has completed with a error:
    Directory C:\SCADA\ScadaTableEditor has to be cleared
    Installation has completed with errors
    #6020
    The problem is that the destination folder is not empty.
    1. Uninstall Rapid SCADA
    2. If the folder C:\SCADA exists, delete it.
    3. Install Rapid SCADA from the beginning.
    #6081
    sokol
    Hi, nearly the same Problem:
    Trying to install latest RapidScada 5.7.1 to Windows10 Pro 64bit with latest updates.
    Installation gives notes and errors:
    Unzip files from C:\Users\ER\Downloads\scada_5.7.1_full_en\Arc\ScadaServer.zip
    Install service ScadaServerService
    Process completed with an error
    Service ScadaServerService hasn’t been installed
    Unzip files from C:\Users\ER\Downloads\scada_5.7.1_full_en\Arc\ScadaComm.zip
    Install service ScadaCommService
    Service ScadaCommService hasn’t been installed
    Go to
    Register ASP.NET
    Unzip files from C:\Users\ER\Downloads\scada_5.7.1_full_en\Arc\ScadaWeb.zip
    Selected application pool: DefaultAppPool
    Register web application Scada
    Create shortcut Webstation
    Installation of Webstation application has completed successfully
    Unzip files from C:\Users\ER\Downloads\scada_5.7.1_full_en\Arc\ScadaAgent.zip
    Install service ScadaAgentService
    Service ScadaAgentService hasn’t been installed
    Unzip files from C:\Users\ER\Downloads\scada_5.7.1_full_en\Arc\ScadaAdmin.zip
    Create shortcut Administrator
    Installation of Administrator application has completed successfully
    Unzip files from C:\Users\ER\Downloads\scada_5.7.1_full_en\Arc\ScadaSchemeEditor.zip
    Installation of Scheme Editor application has completed successfully
    Unzip files from C:\Users\ER\Downloads\scada_5.7.1_full_en\Arc\ScadaTableEditor.zip
    Installation of Table Editor application has completed successfully
    Please restart the computer
    what cn i do?
    Many thanks!
    #6082
    sokol
    hi, new attempt:
    i done the followig operations:
    – uninstall
    – install new
    log says:
    Installation of Communicator application has completed successfully
    Go to
    Register ASP.NET
    Installation of Agent application has completed successfully
    Installation has completed successfully
    i get an error by trying to create a new Modbus KP:
    “Error getting device interface type from the library
    KpModbusSlave.dll: The System do not can find the file
    (0x80070002)
    #6083
    KpModbusSlave.dll is going to be developed on summer 2020. In case of using Modbus master, select KpModbus.dll.
    You can write to https://forum.rapidscada.ru/ if you prefer.
    #6084
    sokol
    ok, many thanks!
    #12250
    TDE
    Trying to install latest RapidScada 5.8.4 to Windows 10 Home 64bit with latest updates.
    Unzip files from C:\Users\3iprecast\Downloads\Compressed\scada_5.8.4_full_en\Arc\ScadaServer.zip
    Installation of Server application has completed successfully
    Unzip files from C:\Users\3iprecast\Downloads\Compressed\scada_5.8.4_full_en\Arc\ScadaComm.zip
    Service ScadaCommService hasn't been installed
    Go to
    Register ASP.NET
    Unzip files from C:\Users\3iprecast\Downloads\Compressed\scada_5.8.4_full_en\Arc\ScadaWeb.zip
    Unzip files from C:\Users\3iprecast\Downloads\Compressed\scada_5.8.4_full_en\Arc\ScadaAgent.zip
    Service ScadaAgentService hasn't been installed
    Unzip files from C:\Users\3iprecast\Downloads\Compressed\scada_5.8.4_full_en\Arc\ScadaAdmin.zip
    Unzip files from C:\Users\3iprecast\Downloads\Compressed\scada_5.8.4_full_en\Arc\ScadaSchemeEditor.zip
    Unzip files from C:\Users\3iprecast\Downloads\Compressed\scada_5.8.4_full_en\Arc\ScadaTableEditor.zip
    • This reply was modified 3 years, 8 months ago by Mikhail.
    #12254
    For some reason, the services were not registered in OS. You should register them manually by executing the items 7-9 from the manual.
