Viewing 15 posts - 3,856 through 3,870 (of 6,302 total)
  • in reply to: Server is unavailable #6540
    Also noticed that /opt/scada/ScadaWeb had infinite directories
    Haven’t faced this before.
    in reply to: Server is unavailable #6538
    There should be 2 connections to SCADA-Server, by the users ScadaComm and ScadaWeb.
    Please check what is written in ScadaServerSvc.txt about active connections.
    Also check ScadaCommSvc.log and ScadaWeb.log
    in reply to: Transfer File from Computer to Rpi #6534
    In Administrator create a new deployment profile for Raspberry. Upload all the configuration except Server settings (because they have different file paths).
    in reply to: New Rapid SCADA 5.7.0 Beta #6532
    I would do the following:
    1. Copy Communicator from the Linux installation package v5.6 to C:\SCADA\ScadaComm1
    2. Copy Communicator from the Linux installation package v5.8 to C:\SCADA\ScadaComm2
    3. Stop the existing Communicator service.
    4. Copy the same configuration to ScadaComm1\Config and ScadaComm2\Config
    5. Run ScadaCommMono.exe of different versions and compare.
    in reply to: Installation Rapid scada on a Raspberry Pi #6530
    Dear Han,
    – How to open on Web browser “Chrome”
    Raspberry has Chromium browser. You can open it from the menu.
    – How to open the Administrator?
    In command line when you inside Administrator’s directory
    mono ScadaAdministrator.exe
    However, I suggest avoid using UI on Linux. It’s better to configure projects and open web pages from another computer.
    • This reply was modified 6 years, 4 months ago by Mikhail.
    in reply to: IEC61107 Protocol driver #6529
    Good news!
    in reply to: Open in Web Browser #6524
    It was a provider failure because of electricity break. Now it works. The first long interruption of service for several years of good operating. Thanks for noticing.
    in reply to: SNMP Device – Value return a comma #6522
    Communicator works as system user, so it uses culture settings for “system”. I don’t recommend to change it, it may cause side effects. It’s just displaying that doesn’t affect real data.
    You should open Administrator – Tools – Language and set fr-FR to apply culture settings to Rapid SCADA GUI and web interface. But currently the language pack doesn’t contain French. So settings affect date and number formatting. If you decide to create a translation to French and share it, I will assist you.
    in reply to: New Rapid SCADA 5.7.0 Beta #6506
    Dear Mr.Han,
    May be you should check timeouts.
    Nothing changed in communication logic.
    in reply to: SNMP Device – Value return a comma #6505
    The screenshot is not available. Please upload it again.
    in reply to: Transfer File from Computer to Rpi #6498
    in reply to: Open in Web Browser #6496
    joeh6966, you should define the views exactly as it’s shown in the videos. No *.rsproj files there.
    in reply to: New Rapid SCADA 5.7.0 Beta #6495
    Read the document mentioned above. First, install new Rapid SCADA on another machine to test. Follow the document to convert the project.
    in reply to: New Rapid SCADA 5.7.0 Beta #6493
    Upgrade from v5.6 to v5.8 is similar.
    in reply to: Open in Web Browser #6484
    The default user Admin has full rights despite you fill the Rights table. Make sure that the view is opened if Admin is logged on.
