Forum Home › Forums › Communicating with Devices › SNMP Device – Value return a comma
- This topic has 8 replies, 3 voices, and was last updated 6 years, 8 months ago by
February 7, 2020 at 2:32 pm #6503
Erwan
ParticipantHello,
I am a beginner in the use of RapidScada and I have just added my first SNMP line !
The communication seems to work, but the value returned by the SNMP driver contains several commas which gives me problem.https://zupimages.net/up/20/06/r8r9.png
Is it possible to delete the commas present in the returned result?Thank you!
This topic was modified 6 years, 8 months ago by
February 7, 2020 at 3:32 pm #6505
The screenshot is not available. Please upload it again.
February 7, 2020 at 3:35 pm #6507Erwan
ParticipantHello,
Please excuse me, I just uploaded my screenshot 🙂
URL : https://image.noelshack.com/fichiers/2020/06/5/1581089654-commas.pngFebruary 7, 2020 at 8:08 pm #6508
manjey73Participantin appearance, this is like a number, the separators depend on the regional settings of the PC
If this is string data, it is unlikely to work without changing the driver…. formulas are useless, since you will only have the first 8 bytes
This reply was modified 6 years, 8 months ago by
manjey73.
February 7, 2020 at 8:45 pm #6510Erwan
ParticipantThe regional settings of my PC are currently set to “FR_fr” which does not use a separator.
Is it possible that the use of the comma separator is defined at the level of the KpSNMP.dll driver?
February 7, 2020 at 8:54 pm #6511
manjey73ParticipantHow is the resulting number displayed in the Scada database?
Yes, you can define regional settings in the code. But I did not study this driver.
manjey73.
February 7, 2020 at 9:07 pm #6513Erwan
ParticipantThe number stored in the database contains no commas.
Unfortunately, with no knowledge in development I would not have the capacity to change the driver.
February 8, 2020 at 5:02 am #6514
manjey73ParticipantDo not pay attention, in SNMP, the variable itself is most likely still text with a label that it is a number. The Communicator displays it probably before sending it to the Scada database. Use the number format in the table to apply the correct multiplier
February 10, 2020 at 6:30 am #6522
MikhailModeratorCommunicator works as system user, so it uses culture settings for “system”. I don’t recommend to change it, it may cause side effects. It’s just displaying that doesn’t affect real data.
You should open Administrator – Tools – Language and set fr-FR to apply culture settings to Rapid SCADA GUI and web interface. But currently the language pack doesn’t contain French. So settings affect date and number formatting. If you decide to create a translation to French and share it, I will assist you.
