Forum Home › Forums › Development and Integration › IEC61107 Protocol driver
- This topic has 11 replies, 3 voices, and was last updated 2 years, 3 months ago by
February 10, 2020 at 10:54 am #6527
manjey73ParticipantGood day everyone. I wrote the iec61107 Protocol driver. So far, only the ability to read in C mode.
The driver was tested on the devices of Russian production according to this Protocol. I would like to expand the driver’s functionality so that it supports more devices that use this Protocol.
The cost of the driver is $ 25, but I can issue keys for a certain period of time for the test.
If someone is interested in this driver and it helps with creating device templates, a discount will be provided.
We need logs for receiving and transmitting devices. And if it is possible to make remote access to the devices, it will also help a lot.
I use an Online translator, so sorry for my English 🙂
Download link – See Driver_IEC61107.zip
This topic was modified 6 years, 8 months ago by
manjey73.
February 10, 2020 at 2:46 pm #6529
MikhailModeratorGood news!
June 29, 2021 at 8:22 am #9170Yatran
ParticipantДобрый день. Имеется возможность протестировать счетчики ACE6000 и SL7000.
Установленая АСКУЕ позволяет вести логи. Интерес к драйверу – построение собственной системы АСКУЕ на базе платформе RapidScada.June 29, 2021 at 8:37 am #9171
manjey73Participant@Yatran сможете организовать удаленный доступ к приборам для тестирования?
И есть ли на них документация производителя о типах запросов и логи например с OPC сервера или перехваченные логгером порта в текстовом и HEX виде ?
На русском форуме тоже тема есть.
This reply was modified 5 years, 4 months ago by
manjey73.
June 29, 2021 at 8:44 am #9173
manjey73ParticipantПо описанию на ACE6000 у него не 61107 а DLMS/COSEM
June 29, 2021 at 8:51 am #9174
manjey73ParticipantIEC62056-21 кажется это обновление протокола 61107, надо будет поизучать и попробовать на живом приборе.
June 29, 2021 at 9:40 am #9176Yatran
ParticipantСоответствие стандартам
Счетчик ACE6000 полностью соответствует следующим стандартам и нормативным
документам.
IEC 62052-11 Electricity metering equipment (AC) – General requirements, tests and test
conditions, part 11: Metering equipment (equivalent to EN 6205-11)
IEC 62053-21 Electricity metering equipment (AC) – Particular requirements, part 21:
Static meters for active energy (classes 1 and 2), (equivalent to EN 62053-21)
IEC 62053-22 Electricity metering equipment (AC) – Particular requirements, part 22:
Static meters for active energy (classes 0,2 S and 0,5 S)
IEC 62053-23 Electricity metering equipment (AC) – Particular requirements, part
23: Static meters for reactive energy (classes 2 and 3)
IEC 62053-31 Electricity metering equipment (AC) – Particular requirements, part 31:
Pulse output devices for electro-mechanical and electronic meters (equivalent to EN
62053-31)
IEC 62053-52 Electricity metering equipment (AC) – Particular requirements, part 52:
Symbols
IEC 62053-61 Electricity metering equipment (AC) – Particular requirements, part 61:
Power Consumption and Voltage Requirements
IEC 62054-21 Electricity metering equipment (AC) – Tariff Load control, part 21:
Particular requirements for time switches (equivalent to EN62054-21)
IEC 62056-21 Electricity Metering – Data exchange for meter reading, tariff and load control – Direct local data exchange (supersedes IEC61107)
IEC 62056-42 Electricity Metering – Data exchange for meter reading, tariff and
load control, part 42: Physical layer services and procedures for connectionoriented asynchronous data exchange
IEC 62056-46 Electricity Metering – Data exchange for meter reading, tariff and load
control, part 46: Data link layer using HDLC protocol
IEC 62056-47 Electricity Metering – Data exchange for meter reading, tariff and
load control, part 47: COSEM transport layers for IPv4 networks
IEC 62056-53 Electricity Metering – Data exchange for meter reading, tariff and
load control, part 53: COSEM Application layer
IEC 62056-61 Electricity Metering – Data exchange for meter reading, tariff and load control, part 61: Object identification system (OBIS)
IEC 62056-62 Electricity Metering – Data exchange for meter reading, tariff and
load control, part 62: Interface classes
European Directive 2004/22/EC for Measurement Instrument Directive (MID)June 29, 2021 at 9:48 am #9177Yatran
На шине RS485 стоит MOXA 5410. Теоретически можно насторить проброс портов для внешнего статического IP адреса.
Этого нет.
Есть возможность получать логи обмена. Но по какому протоколу идет обмен я не в курсе.June 29, 2021 at 9:54 am #9178
manjey73ParticipantНапишите мне на почту, найдете в информации драйвера.
Я пришлю свои выделенные IP (рабочий и домашний)June 29, 2021 at 12:32 pm #9180
MikhailModeratorIt’s an English language forum. Messages on all other languages will be deleted. Use forum.rapidscada.ru
July 16, 2024 at 1:15 pm #14956
manjey73ParticipantUpdated the driver for version 6.
I threw the release on Git, so at least there is an understanding about the number of downloads.Creating templates is still done by hand, even though the graphic part from @JurasskPark is screwed on
July 18, 2024 at 9:58 am #14983
MikhailModeratorThe driver page in the Store is https://rapidscada.net/store/Module/en/KpM61107
