Viewing 15 posts - 3,826 through 3,840 (of 6,302 total)
  • in reply to: Viewing charts and buttons at the same time #6645
    I think, programming is not needed for this task.
    There is a frame component included in Extra Scheme Components Plugin. It allows to insert a chart into a scheme. If this is what you need, I can provide more details. To discuss the existing features, it’s better to create a new topic in Understanding the Software subforum.
    in reply to: How to update to 5.8.0 #6643
    This is confusing. I don’t see any “change notes” anywhere.
    See Version history.
    and all of the data was being collected and displayed
    The Server and Communicator services of Rapid SCADA starts automatically when Windows starts. They don’t need Administrator to be opened.
    in reply to: Question on version 5.8.0 #6641
    It’s normal for version 5.8.0 because the user interface of Server and Communicator is included in the Administrator application.
    in reply to: Compile ScadaAdmin5 #6639
    The manual is here. Does it help?
    in reply to: how to display number in decimal? #6638
    Open the Input channels table, and select the format of input channel.
    in reply to: Events #6628
    1. Please clarify the question.
    2. The screenshot show an event event table. If you need to calculate aggregated values based on events, you should develop a custom report using C#.
    in reply to: Download or upload configuration #6627
    Agent uses port 10002. So 10000 is not correct. Change upload profile setting to the default.
    in reply to: Download or upload configuration #6626
    Try this document. Also check Agent log file to be sure that it’s running. If you have more questions about version upgrade, please create a new topic because this one is inappropriate.
    in reply to: Installation issue #6625
    I have no clue. Sorry for that. Linux means hardcore…
    Can try to fix it for a fee. You would pay only in case of success.
    • This reply was modified 6 years, 3 months ago by Mikhail.
    in reply to: Installation issue #6621
    Possibly, scada.conf was not enabled.
    in reply to: Help witch formula #6618
    Please upload images without ZIP to make possible opening them in browser (not download).
    in reply to: Installation issue #6617
    When you run sudo apt-get install libapache2-mod-mono mono-apache-server4
    did you get any errors?
    in reply to: Help witch formula #6606
    Could you make screenshots of formulas, channels and error?
    in reply to: help me how to check none value or null value? #6605
    With formula
    Stat > 0 ? Cnl : Val()
    you can get the last correct value
    in reply to: Log in web page #6600
    it seems the auto login url use first user account in user table
    Yes, you right. We can upgrade the plugin to select specified user for a fee.
    But I can’t find it from plugin store. where can i check for latest version?
    This is because the plugin has not been properly documented. The link in the forum is up to date.
