How to update to 5.8.0
Forum Home › Forums › Installation Issues › How to update to 5.8.0
Viewing 12 posts - 1 through 12 (of 12 total)
  • #6569
    roska
    In the change notes, I saw that with the latest Version, there are changes in the database. How can I update my existing configuration (which is 5.5.2) to 5.8.0?
    I think I can check and update the configuration files for server and communicator myself if there are changes, but are there any other things to consider?
    #6570
    roska
    OK, now I found the answer in the anouncement of 5.7 that the procedure is the same also for 5.8.
    #6571
    That’s right.
    #6578
    roska
    The last point of the update instruction says: Download the existing configuration into the new project by Administrator.
    But how? Can I do this from the same machine (download configuration from localhost)?
    I tried, but I get an error: Unable to login – invalid username or password.
    • This reply was modified 6 years, 8 months ago by roska.
    #6580
    roska
    error
    #6581
    roska
    OK I think I got it running. For some reason, it seems like the basedat files on this machine were corrupted, but after I copied them from the working linux system, it worked.
    #6583
    Similar situation can occur if you change ScadaAdmin password. In this case, export the User table to user.dat and copy to the server manually.
    #6577
    roska
    The last point of the update instruction:
    https://yadi.sk/i/CIcov9Xjbha-NQ
    says: “Download the existing configuration into the new project by Administrator.”
    But how? Ist this even possible from the same machine? I tried, but I get an error: Unable to login, invalid username or password.
    Screenshot:
    https://roebert.selfhost.eu/scada.jpg
    #6576
    roska
    But how? Ist this even possible from the same machine? I tried:
    error
    but I get an error.
    #6575
    roska
    According to the update instructions:
    Last point:
    I tried:
    error
    But I get an error when I try.
    #6642
    joeh6966
    This is confusing. I don’t see any “change notes” anywhere.
    Do I need to update when I am very happy with the setup that I have.
    I have version 5.5.2 running. It even runs when I have to do a re-boot of windows 8.1 and I re-started my other programs yesterday, but forgot to click on Administrator in my Start menu. When I clicked on it today, the incandescent light bulb shows up in my Taskbar, and all of the data was being collected and displayed even though I thought they wouldn’t be.
    #6643
    See Version history.
    The Server and Communicator services of Rapid SCADA starts automatically when Windows starts. They don’t need Administrator to be opened.
