To display current date and time, try the formulaNow()orUtcNow(), and set appropriate channel format.
Severity, specified for a channel status, will be set for generated events if a channel has that status.
For now, the web interface uses only main color. The second and back color columns are made for future use.
The example is for v5. It does not work with v6.
Use the appropriate web page for v6.
Open browser tool by pressing F12 and check the actual page URL.
If there is a question, please clarify it.
Numeric address = device address (eg Modbus device address using 2 or 3 or ..)
String address = Call number (IP address to be connected for the device eg 192.168.17.21 or others)Yes. You can enter 127.0.0.1 into String Address.
Notification Plugin for v6 is not developed yet.
Archive mask specifies what archives store channel data. If empty, the default archives are used.
Tag number is the synonym of the Signal field in the 5th version.
Tag code is similar to tag number, but it can contain any string.Data type of the channel determines how channel data are stored. The empty cell means Double.
When you send a custom command, the driver sends data that is specified for the command.
MikhailModeratorThere is a DB Export module that can write data to MSSQL.
We don’t have a plan to develop MSSQL archive (similar to ModArcPostgreSql, for example). It can be done by other developers, or we can implement MSSQL archive by a contract.
MikhailModeratorDear Han,
Rapid SCADA includes a driver KpSms.dll that supports AT command set for sending SMS. To answer if a certain module works with the driver or not, you should test them together.
MikhailModeratorThank you. The drivers will be included in the next release.
Can the team help to prepare the video support if we can learn to use the new version V6 in a faster way?
I suggest creating a demo project to learn the v6 faster. If something is not clear, ask on the forum.
Could you provide screenshots? -
