March 20, 2023 at 9:57 am in reply to: archived data more the 30days, it cannot be displayed normally #12266
Can’t reproduce the issue on my machine, unfortunately. Is it possible to provide HTTP access to the web application to be able to open a chart over the internet?
This forum is in English. For using Russian, please write on https://forum.rapidscada.ru/
MikhailModeratorLine State – Undefined status is a minor bug. Thank you that you found it. Will be fixed in the next release.
Try another broker that works for me: https://ibb.co/yn2w488
You should choose “MQTT Client” for a device, not “MQTT”.
MQTT Client is the new driver for v6.
Don’t forget to set Communication Channel = MQTT client in the line options.
In case of issues, please provide links to screenshots of your settings and errors.
MikhailModeratorAnd my last question
Ask as many questions as needed.
MikhailModeratorPostgreSQL is the main DBMS for Rapid SCADA. Therefore, there are special features for this database.
MikhailModeratorYou should create your own stored procedures that fill code and name and use them in the Export to DB module. However, it is not optimal.
In case of using PostgreSQL, you can upload the project to the database, so you can find channel code and name by its ID.
For some reason, the services were not registered in OS. You should register them manually by executing the items 7-9 from the manual.
Elastic Report supports multiple sections of the same type in a report.
You should check the error details in ScadaWeb.logMarch 16, 2023 at 11:09 am in reply to: archived data more the 30days, it cannot be displayed normally #12247
MikhailModeratorI will try to use the available information. If that’s not enough, I’ll ask.
March 16, 2023 at 7:47 am in reply to: archived data more the 30days, it cannot be displayed normally #12245
MikhailModeratorThank you.
Next week I will try to reproduce the issue, and write about the results here.
MikhailModeratorThe issue is not related to nginx. .NET is not properly installed.
March 15, 2023 at 8:36 am in reply to: archived data more the 30days, it cannot be displayed normally #12237
MikhailModeratorIn the console image, could you switch the second “Console” tab to Console also? And then press F5 to refresh the page and get messages into the console.
MikhailModeratorTo export data to MySQL, use the Export DB module, located in Server – Modules.
I don’t know if MySQL supports XML functions like Postgres. -
