Viewing 15 posts - 1,861 through 1,875 (of 6,290 total)
  • in reply to: Chart not Displaying Data #12445
    What language is set in the Administrator app – Tools – Language?
    Try generating an Excel report for channel 4101 to check channel data.
    in reply to: modbus transfer string value #12444
    Why don’t you do the following:
    1. Set the default by order 01234567
    2. Get string as is.
    3. Draw tables with the expected and actual strings. Draw arrows from one table to another to find proper byte order.
    in reply to: Webstation error #12443
    Could you create a new topic please? Sorry for the inconvenience.
    in reply to: Auto Report #12435
    Hi Roxy,
    Will it be possible to just automatically save reports on a designated folder without emailing it?
    Yes, there is an option for this.
    I already have a license for Elastic Report, do i still need auto report for auto generation ?
    Auto Report requires it’s own license, because it’s a different application that adds useful features. The Auto Report app does not need Elastic Report key for generating reports. But’s it’s more comfortable when you have the both licenses, because web plugin Elastic Report is handy for development reports, and sometimes a user needs report in time.
    in reply to: modbus transfer string value #12433
    1. Copy the valid variable name from here: ArrIdx
    I and l are different characters.
    2. Find the appropriate byte order.
    in reply to: Webstation error #12432
    The topic called “Webstation error”, but the error is displayed in Communicator. You should check the Communicator log file.
    in reply to: DrvDbImportPlus ERROR #12423
    Probably the error is caused by version mismatch.
    Check the current version of SCADA\ScadaAdmin\ScadaCommCommon.dll
    in reply to: modbus transfer string value #12422
    Byte order is set in the template options https://ibb.co/9wWZHG4
    Could you make a screenshot of the settings and the error?
    in reply to: Webstation URL #12421
    The last question is off topic. Please post in the appropriate thread.
    in reply to: error when uploading configuration #12415
    Instance configuration is stored in *.rsproj file. You should open a project file in a text editor and check what is inside.
    If instance content is disappeared, probably the project file has been damaged. You should take the project from a backup copy.
    in reply to: export data to MS SQL #12413
    You should check the log file of the module. Select Modules in the log filter combo box.
    in reply to: modbus transfer string value #12412
    Currently it does not work with ulong data type. We should add this option in the future.
    in reply to: modbus transfer string value #12411
    Byte order in the Modbus template is 76543210
    in reply to: modbus transfer string value #12410
    in reply to: export data to MS SQL #12407
    You should check log files of the module.
