error when uploading configuration
Forum Home › Forums › Uncategorized Issues › error when uploading configuration
  • #12398
    tonielhage1
    Unhandled exception:
    Could not find default endpoint element that references contract ‘AgentSvcRef.AgentSvc’ in the ServiceModel client configuration section. This might be because no configuration file was found for your application, or because no endpoint element matching this contract could be found in the client element.
    how to solve it. note this problem is recently happened, before there was no problem
    best regards
    tony
    #12400
    tonielhage1
    https://ibb.co/ZL31KJ6
    • This reply was modified 3 years, 6 months ago by Mikhail.
    #12415
    Instance configuration is stored in *.rsproj file. You should open a project file in a text editor and check what is inside.
    If instance content is disappeared, probably the project file has been damaged. You should take the project from a backup copy.
