Interesting idea. I suggest to try creating a module for the Server app, because it’s more flexible than formulas.
MikhailModeratorInstead of that formula, use
Cnl; 15which fits for channel of the Input/output type.September 18, 2023 at 9:09 am in reply to: HeideSQL Access to Default PostgreSQL Archive Database #13413
MikhailModeratorCheck the tools such as DatViewer-v6 and TrendTableViewer-v6 that allow to view *.dat files. Tools for editing have not been developed yet. Use ScadaTestClient-v6 to update data in archives.
I hope that the DAT viewers will be updated to editors later.September 18, 2023 at 9:06 am in reply to: HeideSQL Access to Default PostgreSQL Archive Database #13412
MikhailModerator*.dat format is not proprietary, it’s documented and can be used by anyone for free.
I suppose, you can use HeideSQL or DBeaver to connect to PostgreSQL. However, there is a default tool, named pgAdmin. Username, password and port are specified during PostgreSQL installation.
MikhailModeratorIf you don’t change the Webstation configuration, untick the associated checkbox to avoid unnecessary start/stop actions.
MikhailModeratorYou can find commands in SCADA\ScadaWeb\*.bat
MikhailModeratorYou right. On Windows, IIS manages the web application. While on Linux there is a service for ScadaWeb.
The Administrator app sends a command to IIS to restart. Sometimes it takes a long. Even if you run the same command from a command line, the result would be the same. For now, I have no idea how to fix that programmatically. As for me, I open IIS management console and restart the web app using it. There is no delay in this way.
This issue presents only on Windows.
MikhailModeratorWhy isn’t “ScadaInstanceConfig.xml” file shown as a “child” object in the “Administrator” application’s GUI
Because ScadaInstanceConfig.xml is not a part of a user’s project. It’s possible to develop an extension that provides UI for editing ScadaInstanceConfig.xml.
MikhailModeratorDo you mean creating nested folders in the View Explorer tree?
MikhailModeratorThank you 🙂
MikhailModeratorIn the Views table you should set the view type for the record with ID=7.
Tables and schemes are detected by their file extension, while dashboards use common extension XML.
MikhailModeratorI also cannot open the screenshots. Please check.
Links in the 2nd message work.-
This reply was modified 2 years, 9 months ago by
According to the settings, events should be generated when channel status has changed. Does the channel status change when you change channel value from -1 to 1, for example?
Next time, please make screenshots in English.
MikhailModeratorAutomatic Control Module works in this way. It can send command when condition is met. According to the command, channel value can be simply increased.
