Forum Home › Forums › Development and Integration › HeideSQL Access to Default PostgreSQL Archive Database
- This topic has 5 replies, 3 voices, and was last updated 2 years, 10 months ago by
Anonymous.
September 15, 2023 at 5:55 pm #13398
yotool
Participant** Is it possible to connect directly to the default PostGreSQL archival database using HeideSQL (or similar alternatives)?
** Is the PostgreSQL listening on the “standard” TCP port 5432?
** What is the default user-name and password to establish this possible direct connection?
Thanks for your thoughts.
September 16, 2023 at 2:56 am #13399yotool
ParticipantOk…
I now see that you ar still, by default using your proprietary *.dat archive file format.
** As I asked in a different thread, how can I “edit” the “minute” and “hourly” data entries in Rapid Scada v.6.1 as in the previous 5.X “Server” application”?
That feature was useful for fixing known-bad historical data entries.
Thanks.
September 17, 2023 at 6:00 pm #13403yotool
Participantupdate:
I believe I now see how minute/hour/daily archives can be redirected to PostGreSQL.
I have PostGreSQL installed on the local Rapid Scada Windows 10 host.
I have HeideSQL also properly communicating with the default PostGreSQL service running on the standard TCP/IP port for PostGreSQL.
If optionally configured to use the PostGreSQL database engine, I can use this technique to read/write Server module “Archive” data, and take full advantage of all of the PostGreSQL features, but I’m just asking if the proprietary *.dat files can be “edited” as in the past.
Thanks for the help.
September 18, 2023 at 9:06 am #13412
MikhailModerator*.dat format is not proprietary, it’s documented and can be used by anyone for free.
I suppose, you can use HeideSQL or DBeaver to connect to PostgreSQL. However, there is a default tool, named pgAdmin. Username, password and port are specified during PostgreSQL installation.
September 18, 2023 at 9:09 am #13413
MikhailModeratorCheck the tools such as DatViewer-v6 and TrendTableViewer-v6 that allow to view *.dat files. Tools for editing have not been developed yet. Use ScadaTestClient-v6 to update data in archives.
I hope that the DAT viewers will be updated to editors later.November 27, 2023 at 12:40 pm #13715Anonymous
InactiveUse a PostgreSQL-Compatible Client:
pgAdmin:
pgAdmin is a popular PostgreSQL administration and management tool. It’s specifically designed for PostgreSQL and provides a user-friendly interface.
Download and install pgAdmin from the official website: https://www.pgadmin.org/
Connect to your PostgreSQL server using the appropriate connection details.DBeaver:
DBeaver is a universal database tool that supports various database management systems, including PostgreSQL.
Download and install DBeaver from the official website: https://dbeaver.io/
Create a new database connection, select PostgreSQL as the database type, and provide the connection details. -
