Webstation v.6.1.x
Forum Home › Forums › Understanding the Software › Webstation v.6.1.x
  • #13402
    yotool
    Rapid Scada 6.1.x:
    I see that there are corresponding Windows “Services” for the Rapid Scada “Agent”, “Communicator”, and “Server” components.
    But there is no such direct service for the “Webstation” component.
    ** Is this represented by the Scada “Website” component of MS Internet Information Services (www)?
    Occasionally when “Uploading” my project (usually when I do it very often in a short time-period), both the STOPping and STARTing of the “Webstation” component “Fails”.
    If I wait for some time and retry, it usually succeeds.
    #13409
    You right. On Windows, IIS manages the web application. While on Linux there is a service for ScadaWeb.
    The Administrator app sends a command to IIS to restart. Sometimes it takes a long. Even if you run the same command from a command line, the result would be the same. For now, I have no idea how to fix that programmatically. As for me, I open IIS management console and restart the web app using it. There is no delay in this way.
    This issue presents only on Windows.
    #13410
    You can find commands in SCADA\ScadaWeb\*.bat
    #13411
    If you don’t change the Webstation configuration, untick the associated checkbox to avoid unnecessary start/stop actions.
    #13418
    yotool
    Acknowledged and thank you for the replies.
