Viewing 15 posts - 931 through 945 (of 6,289 total)
  • in reply to: Rest API integration #15109
    A driver does not write data to input channels directly. It writes data to a tag. Communicator binds tags to channels. Data sources send tag data to Server according to the bindings. Use DrvSimulator as an example.
    • This reply was modified 1 year, 10 months ago by Mikhail.
    in reply to: Fixed certain channels in ChartPro #15108
    You can use Chart Pro as a view with the predefined channels. Check this link.
    in reply to: Rest API client communication #15103
    RESP API functions provided by Rapid SCADA can be found here. URL examples are given in the source code. You can call them either from client or server code.
    in reply to: Channel Read Bits #15101
    Binary format will be supported in the next release.
    in reply to: Rest API integration #15100
    Check ScadaComm.log for error. Probably the communication line is not started, therefore its log does not exist.
    If you need to do some calculations based on the measurements, it’s possible to develop scripts that implement it.
    Using Rapid SCADA you can collect data from various devices, store data into a database, and display to an operator. I suggest to start from watching video lessons and reading docs (link).
    in reply to: Sequential Running of Outputs #15096
    1. When creating a time trigger, you can enter time with seconds. If it’s doesn’t work for you, please provide a screenshot.
    2. If it should repeat not too fast, you can enter many times of day in the trigger options. Alternatively, you should create a channel that changes from 0 to 1 every X minutes, and create a data trigger that reacts on the channel.
    in reply to: Sequential Running of Outputs #15092
    Try creating a time trigger in Automatic Control Module. Use the Delay parameter of commands to send them as a sequence.
    in reply to: First time update of Digital Output status #15091
    Please provide links to screenshots.
    in reply to: OPC DA no values received #15086
    > Is there any way one can support you?
    Purchase of any additional modules is appreciated.
    in reply to: Integrating 3 colour LED Module #15084
    Automatic Control Module is useful when you need to send commands according to conditions.
    First, connect the equipment and try sending commands manually. After you make it work, use ACM.
    in reply to: Rest API integration #15082
    In Visual Studio 2022 Community when create a new project.
    in reply to: OPC DA no values received #15081
    You should try the setup the ScadaComm6 service to work as the OPCSrv user. See this.
    It’s enough to restart Communicator that works as a service or application.
    in reply to: Change default port number 10008 #15074
    If you didn’t change the port during installation, use the method described above.
