Change default port number 10008 Forum Home › Forums › Installation Issues › SCADA-Web Installation › Change default port number 10008 This topic has 3 replies, 3 voices, and was last updated 2 years, 2 months ago by kcks66. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts July 31, 2024 at 6:34 am #15072 kcks66Participant Hi Mikhail, Currently my PC other application is using 10008. Thus I want to change the Rapid SCADA default port number to other number. http://localhost:10008 to http://localhost:8080 However I look around Administrator I couldn’t find where is the port number setting is. Pls advice and thank you. July 31, 2024 at 7:59 am #15073 manjey73Participant WEB ports are configured in IIS on Windows or in nginx settings on Linux July 31, 2024 at 9:42 am #15074 MikhailModerator Hi, If you didn’t change the port during installation, use the method described above. July 31, 2024 at 1:14 pm #15075 kcks66Participant Hi manjey73 & Mikhail, Got it changed to 8080. Thank you. Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
