Viewing 15 posts - 541 through 555 (of 6,288 total)
  • in reply to: V6 Automatic Login feature #16389
    Automatic login is the same for the entire web application.
    To use another login/password, deploy an additional instance of the web application. It can be done on the same or another computer.
    in reply to: Disconnect from OPC DA server #16388
    > Rapidscada and the OPC DA Server are running on different machines.
    When OPC DA server and client are installed on different machines, it requires setup of DCOM security. You should search for DCOM manuals. Sometimes a user manages to run it.
    I recommend installing Communicator on the same machine where the OPC server is already installed.
    in reply to: Table format for web view #16385
    Schemes can display current data as a table. However, it requires manual data binding between cells and channels.
    in reply to: Event marker not found #16384
    Received. What hardware, operating system and file system is used?
    in reply to: Event marker not found #16381
    If writing an event is not properly finished because of power outage, new events will be successfully written in the file when server continue operating.
    An exception situation like “Event marker not found” occurs when an event file is corrupted, i.e. contains invalid data.
    If you need this issue solved, publish the corrupted file to be possible to analyze it it’s possible to restore them or not. If the problem occurs often, a special module can be developed to check and restore corrupted event files before the Server service starts.
    in reply to: XML Content Translator for SCADA 6 #16380
    in reply to: information of the Archive #16379
    Likely, the directory that are set by default does not exist. Choose the correct directory by clicking the Browse button.
    in reply to: information of the Archive #16378
    Please check the selected “Trend table directory”. Does it contain data files?
    Can you view historical data via the web interface?
    in reply to: Configuring DrvMqttPublisher #16377
    MQTT Publisher sends data tag by tag. Payload format is configurable. I suggest to try. It does not require much efforts.
    in reply to: XML Content Translator for SCADA 6 #16372
    Thank you!
    I will try to merge it, and write here when completed.
    in reply to: Configuring DrvMqttPublisher #16371
    No, unfortunately. Set up intuitively. Write here in case of issues, providing screenshots.
    in reply to: XML Content Translator for SCADA 6 #16367
    In the next release zh-Hans will be added to the drop-down list. Do you have a script to rename all the files in the translation back to *.zh-Hans.xml?
    in reply to: XML Content Translator for SCADA 6 #16366
    This line of code filters the culture list. May be all cultures should be added to the list without any filtering.
    in reply to: information of the Archive #16365
    It looks like there is not data in the archive.
    Try opening the default archive written by the HelloWorld project.
    in reply to: information of the Archive #16361
    Use the TrendTableViewer utility to view data.
