Forum Home › Forums › Understanding the Software › information of the Archive
- This topic has 14 replies, 3 voices, and was last updated 1 year, 2 months ago by
詹森.
April 22, 2025 at 6:05 am #16356
詹森
Participant/opt/scada/Archive/Hour/hour20250422_0001.dat
/opt/scada/Archive/Min/min20250422_0002.datHello, thank you for your help. I would like to ask how to read the xx.dat content information of the Archive?
April 22, 2025 at 9:12 am #16361
MikhailModeratorUse the TrendTableViewer utility to view data.
April 23, 2025 at 5:34 am #16363詹森
Participantpicture1 :
I have downloaded and opened the file. I configured “Archive” in the Channel, but when I opened the downloaded file with the software you provided, I didn’t find any data. I confirmed that the file size is 4M. When I changed the file to another device, it also displayed as shown in the picture. Is this normal? Thank you!
April 23, 2025 at 11:02 am #16365
MikhailModeratorIt looks like there is not data in the archive.
Try opening the default archive written by the HelloWorld project.April 28, 2025 at 8:16 am #16375詹森
ParticipantI tried to run the HelloWorld project for about ten minutes, generating records every minute. When I opened it, I still didn’t see any data. The pictures were the same as before. Could you please help me take a look? Thank you!
April 28, 2025 at 8:19 am #16376詹森
April 28, 2025 at 12:00 pm #16378
MikhailModeratorPlease check the selected “Trend table directory”. Does it contain data files?
Can you view historical data via the web interface?April 28, 2025 at 12:01 pm #16379
MikhailModeratorLikely, the directory that are set by default does not exist. Choose the correct directory by clicking the Browse button.
June 19, 2025 at 12:00 pm #16488詹森
ParticipantLook at the latest pictures I sent. All the files have been recognized. I have confirmed that there are files and they are all recognized, but they can’t be opened. This indicates that there are files and data. It seems that the tool software can’t open them. Could you please help confirm this? Thank you
June 19, 2025 at 1:36 pm #16489
manjey73ParticipantYou need to replace the used dll files from the current version of Scada in the utilities
June 19, 2025 at 2:20 pm #16490詹森
ParticipantThank you for your help,thankful
June 20, 2025 at 11:58 am #16491
MikhailModeratorPlease make a screenshot of the C:\SCADA\Archive directory that is used in your screenshot.
June 20, 2025 at 12:22 pm #16493詹森
ParticipantThe problem has been solved. Just as you said, replacing the file has nothing to do with the directory
June 23, 2025 at 10:23 am #16496
MikhailModeratorBy default, the utility uses the old path. It should be updated someday.
June 23, 2025 at 10:37 am #16498詹森
ParticipantOK,Thank you
