Table format for web view
Forum Home › Forums › Development and Integration › Table format for web view
  • #16383
    zzmMG
    Hello there,
    I want to display data in a different table format:
    – column: devices list (same model but in different area)
    – row: variables
    Every cell would display the value of one variable for each device.
    This is intended for data summary display.
    Is there any module doing that already?
    Thank you
    #16385
    Schemes can display current data as a table. However, it requires manual data binding between cells and channels.
    #16397
    grhsc
    I also have a question with the format change.
    The current default table has time in the first row and parameters in the first column. Can it be transposed, that is, the first row is the parameter and the first column is the time?
    The reason for this question is that I only have 10 parameters, but I need one minute of data (all day). If I use the current default table format, there will be 1440 columns and 10 rows. This table is weird and not easy to read.
    thank you
    #16399
    You could try to insert an Elastic Report in HTML format as a web page view.
    It will display what you need, but without automatic refresh.
    • This reply was modified 1 year, 6 months ago by Mikhail.
