Elastic Report doesn’t work with events. It works with data archive.
MikhailModeratorI had edit link but it disappeared after few minutes.
The forum engine works so.
If you download Rapid SCADA 5.5.0 before the 26 of December:
“There were 2 outdated files in the package: PlgScheme.dll, ScadaSchemeCommon.dll. The issue is now fixed. Download the distributive again and update these files.”
It was written here.If it doesn’t help, press F12 in browser and make a screenshot of errors in the Console tab.
I would like to merge and edit my post, is it possible?
Do you have the Edit link above your post?
December 29, 2017 at 7:19 am in reply to: "CreateDaSubscr()" method in "KpOpcLogic.cs" can't get value. #2983
MikhailModeratorBy default the service works as system user. You can change a user in the properties of the service.
December 29, 2017 at 7:19 am in reply to: "CreateDaSubscr()" method in "KpOpcLogic.cs" can't get value. #2982
The service and the GIU works as different Windows users with different privileges. You can check user names in Task Manager. This is important when use OPC.December 25, 2017 at 12:18 pm in reply to: Comparing the previous value of channel with the current value of same channel #2977
MikhailModerator
You should create an input channel of Calculated Discrete type for each bit and use the formula GetBit for these channels
Example: GetBit(Val(101), 1) – gets 1st bit from channel 101
First of all, remove the existing installation of Rapid SCADA.
Open Windows features list and check the required options needed for the web app, see images at http://doc.rapidscada.net/content/en/installation-and-run/software-installation.html
Login behavior will be improved in the next version of Rapid SCADA. You should try it when the new version will be published.
Change the fore color to “Status”. The color of the component will reflect channel status.
I can help you step by step by providing online training. If you are interested in the training, please contact me by email.Also I can help you on this forum. In this case, I need the specific questions to answer.
MikhailModeratorI can create such formula for you for a fee.
MikhailModeratorYou can try writing command files from a function specified in the configuration database.
MikhailModeratorSome of TPC devices support multiple connections, some not.
It’s possible, but it may be changed in the future versions.
You can create special files to start/stop communication lines in C:\SCADA\ScadaComm\CmdCommand files examples: https://yadi.sk/d/MDH-CrFW3PnjTh
Also see SaveCmd function.
