Word – bit integration
Forum Home › Forums › Development and Integration › Word – bit integration
  • #2973
    Marko
    I have a question about getting some bits out of some word (int). One word will contain 5 bits that corresponding to some status lamps for example. Bit 0 will turn off-on Lamp 1, bit 1 will turn off-on Lamp 2… Is there any way to accomplish this goal.
    #2974
    You should create an input channel of Calculated Discrete type for each bit and use the formula GetBit for these channels
    Example: GetBit(Val(101), 1) – gets 1st bit from channel 101
    #2975
    Marko
    It’s working. Thank you.
