Viewing 15 posts - 481 through 495 (of 6,288 total)
  • in reply to: Alignment of web controls in V6 #16600
    At the moment, I prefer to set the same width and height for text components, it simplifies to align them manually.
    in reply to: Alignment of web controls in V6 #16599
    This feature will be implemented in the new editor. But I don’t know when it is ready.
    https://ibb.co/ZRHS49Ym
    in reply to: Unable to start Comminication #16597
    2025-07-06 21:50:28 [RANUI-SOLAR][RANUI-SOLAR$][ACT] Data source ScadaServer: Receive the configuration database
    Common cause is that the Server service cannot start. So you need to open ScadaServer.log and check the error messages for the details.
    Formulas are compiled as a single script when Server starts. If they contain a typo, they cannot be compiled. Script Check Extension may be useful.
    in reply to: Send Commond #16596
    Commands can be sent:
    – Using Automatic Control Module
    – With a custom module developed by yourself in C#
    in reply to: ModAlarm V6.4.1.0 fork #16584
    in reply to: DrvFreeDiskSpaceJP #16583
    in reply to: rapidgate #16582
    What protocols are used by the devices?
    in reply to: rapidgate #16581
    You can find the same document in English here.
    Rapid Gate is designed to be installed on a one server. The module can send and receive data.
    There is Replication Module included in Enterprise edition. It sends commands to Communicator to start and stop polling.
    in reply to: Reading event log from modbus device #16580
    Is the code of this S2000-PP driver available for review?
    It’s proprietary. If you decide to develop you own driver, I will copy some parts of the source code that can help.
    in reply to: Reading event log from modbus device #16575
    > The last event is under 0x1000, the pass under 0x1008, and so on.
    After the last event is read by the driver, is the previous event moved to the address 0x1000?
    If so, it’s possible to use the existing driver.
    If not, you need to develop a driver based on the existing. For example, I had to develop a driver (named S2000-PP) in similar situation.
    in reply to: Internal Channels #16574
    > Is it possible to create a channel which is not linked to real world IO
    Yes.
    > or alternatively to create mutiple channels linked to the same IO.
    Only one channel can get data from a data tag of Communicator. Other similar channels should take data of the 1st channel using the formula Data(1)
    in reply to: Store the data in the database #16564
    The 1st active current data archive is Cur. If you deactivate it, current data will be read from the archive, having the code CurCopy.
    in reply to: Reading event log from modbus device #16563
    Automatic Control Module sends commands to a device. Commands can be for writing a register, and for polling a device.
    in reply to: The archived file is lost. #16555
    Historical file is created when a data point with the corresponding timestamp received by Server. UTC time is used. If you time zone is UTC+9, it’s correct.
    in reply to: Time string format and Locale #16554
    > Is the any method to alter the default shorttime format of zh-CN globally (system / scada level).
    I suppose, it’s hardcoded somewhere in .NET framework.
