Forum Home › Forums › Uncategorized Issues › The archived file is lost.
- This topic has 6 replies, 2 voices, and was last updated 1 year, 3 months ago by
詹森.
June 30, 2025 at 2:14 am #16532
詹森
ParticipantDuring the usage process, the device was not shut down or restarted and maintained normal operation. However, the situation of “Archive” loss still occurred frequently. The software version is “rapidscada_6.3.1_linux_en”. Please help reply. Thank you
/opt/scada/Archive/Min/Min20250629# ll -h
Total dosage 61M
drwxr-xr-x 2 root root 4.0K 6月 29 20:00 ./
drwxr-xr-x 61 root root 4.0K 6月 30 09:13 ../
-rw-r–r– 1 root root 4.7M 6月 29 08:59 min20250629_0001.dat
-rw-r–r– 1 root root 4.7M 6月 29 09:59 min20250629_0002.dat
-rw-r–r– 1 root root 4.7M 6月 29 10:59 min20250629_0003.dat
-rw-r–r– 1 root root 4.7M 6月 29 11:59 min20250629_0004.dat
-rw-r–r– 1 root root 4.7M 6月 29 12:59 min20250629_0005.dat
-rw-r–r– 1 root root 4.7M 6月 29 13:59 min20250629_0006.dat
-rw-r–r– 1 root root 4.7M 6月 29 14:59 min20250629_0007.dat
-rw-r–r– 1 root root 4.7M 6月 29 15:59 min20250629_0008.dat
-rw-r–r– 1 root root 4.7M 6月 29 16:59 min20250629_0009.dat
-rw-r–r– 1 root root 4.7M 6月 29 17:59 min20250629_0010.dat
-rw-r–r– 1 root root 4.7M 6月 29 18:59 min20250629_0011.dat
-rw-r–r– 1 root root 4.7M 6月 29 19:59 min20250629_0012.dat
-rw-r–r– 1 root root 4.7M 6月 29 20:43 min20250629_0013.dat
-rw-r–r– 1 root root 50 6月 29 08:00 min20250629_meta.datJune 30, 2025 at 2:16 am #16533詹森
ParticipantThe files being viewed range from min20250629_0001.dat to min20250629_0013.dat. Under normal circumstances, there are min20250629_0001.dat to min20250629_0024.dat
June 30, 2025 at 11:25 am #16540
MikhailModeratorTry enabling writing to log in the archive options. It will create a separate log file ModArcBasic_Min.log. Then check the log file for errors.
Did some files disappear or they never been created?June 30, 2025 at 11:27 am #16541
MikhailModeratorWhat device do you use to run Rapid SCADA?
June 30, 2025 at 11:42 am #16542詹森
ParticipantI’m using an ubuntu system device. I’d like to ask why “min20250629_0001.dat” was created at 08:59? What if it is not created at 0 o ‘clock?
July 1, 2025 at 1:42 pm #16555
MikhailModeratorHistorical file is created when a data point with the corresponding timestamp received by Server. UTC time is used. If you time zone is UTC+9, it’s correct.
July 1, 2025 at 1:51 pm #16558詹森
ParticipantUnderstand,Thank you for your answer
