rapidgate
Forum Home › Forums › Uncategorized Issues › rapidgate
Viewing 10 posts - 1 through 10 (of 10 total)
  • #16577
    Zeus
    Hello, I have encountered a situation where I have two hosts as primary and backup, both running scadaserver. Both servers are responsible for data storage. Can I run the RapidGate module in each server to write data to each other to ensure data integrity?
    When host A stops recovering, host B synchronizes data with A. When host B stops recovering, host A synchronizes data with B. This feels strange to use, what should I do?
    #16579
    Rapid SCADA backup strategy.pdf
    For the Enterprise version, there is a backup module that somehow manages the RapiGate module in this case.
    Ask for a description of this module to understand the process.
    If you have two free versions, then you need to think about how to organize it, it is quite possible that you can somehow do a similar control using, for example, an automatic Control Module
    #16581
    You can find the same document in English here.
    Rapid Gate is designed to be installed on a one server. The module can send and receive data.
    There is Replication Module included in Enterprise edition. It sends commands to Communicator to start and stop polling.
    #16582
    What protocols are used by the devices?
    #16589
    Zeus
    where can i get the Replication Module
    and i use mqtt protocols
    #16601
    If you email me, I will send a link. Replication Module is a part of Enterprise edition.
    #16680
    Zeus
    Hi
    I have sent email but no response
    #16681
    I sent a response on July 08. Is it put in the spam folder?
    #17503
    oley
    Hi Mikhail,
    I take a look at RapidGate and another backup strategies.
    The link to the English document does not work.
    Would you provide a valid link?
    #17505
    Sure
    Link
    It is also can be found from here https://rapidscada.org/product/documentation/ then Additional documentation.
