Viewing 15 posts - 4,906 through 4,920 (of 6,294 total)
  • in reply to: ModDBExport to Oracle #3519
    It seems like server executes requests too long. Can you stop the Communicator service and send current data using Server’s Generator?
    How many record already contained in the table cnldata ?
    in reply to: ModDBExport #3518
    OK, write here to continue the topic.
    in reply to: Source Code KpOpc.dll #3517
    Of course, sorry ))
    Would you create a release of your driver on GitHub to allow others to easily use the driver?
    in reply to: Modbus Slave mode #3516
    Hi catcute,
    Could you explain the idea what you are going to implement?
    Even if you switch operating mode to Slave, the existing Modbus driver works as master. Slave means that Communicator waits for incoming connection, TCP slave (TCP server) not Modbus slave.
    in reply to: Source Code KpOpc.dll #3502
    How do you integrate node-opcua with .NET?
    in reply to: ModDBExport to Oracle #3501
    Please find the *.log file of the module in SCADA\ScadaServer\Log\ and check the errors in this file.
    in reply to: arduino #3500
    Thank you!
    Does it work with Arduino Nano and Uno?
    in reply to: ModDBExport #3491
    When we modify Communicator the next time, likely we will create the necessary options. If you need this changes in time, we could talk about purchasing the development.
    in reply to: ModDBExport #3490
    I thought this was an issue in your program and I was trying to help. I still think that sending data twice if you active the “Sending all device data period” option is an issue.
    Thanks a lot. Your help is very useful.
    I also think, that we should create more options to configure how Communicator sends data to the server.
    Double recording is an issue. I suppose, it sends data the 1st time after communication session and the 2nd time when an interval ends. This is a part of the whole task – optimizing data sending algorithm and adding more options of it.
    The video is very small. Is there a button to make it larger? I can’t recognize what is shown in the video.
    in reply to: Value scaling #3489
    this just crashes the server
    To fix it, you need to read and understand a message in the server log file.
    in reply to: Source Code KpOpc.dll #3488
    Cool! What Linux have you tested with the driver?
    Can you suggest a simulator of OPC UA server?
    in reply to: arduino #3487
    What mgsmodbus allows you to do, in short?
    in reply to: Invert command logic #3486
    Yes, use the formula for the output channel:
    Cmd > 0 ? 0 : 1
    If I did a mistake in the formula, let me know.
    in reply to: Source Code KpOpc.dll #3476
    Thanks a lot!
    Could you create a release on the GitHub repository and put there the necessary DLLs? Like here
    What is the current state of the development? Is it ready enough to be used by the users?
    in reply to: OPC Server Connection – E_NETWORK_ERROR #3475
    In this case, if it’s possible, we should contact with the OPC server developers and works with the to fix the issue. I can assist you in email conversation. We did the same thing to fix another OPC server for BACnet (I forgot its name).
