Invert command logic
Forum Home Forums Communicating with Devices Modbus Invert command logic
This topic contains 2 replies, has 2 voices, and was last updated by  Pieter 11 months, 2 weeks ago.
  • #3481
    Pieter
    Hi.
    I have a relay board (active low) connected to my arduino with modbus tcp.
    The module uses a high input to switch the relay off and n low input to switch it on.
    From the command when a click ON the relay switches off and vice versa.
    Is there a way to invert the command?
    ON = 0
    OFF = 1
    #3486
    Yes, use the formula for the output channel:
    Cmd > 0 ? 0 : 1
    If I did a mistake in the formula, let me know.
    #3497
    Pieter
    Thank you. I just tested it. Now it works as I expected it to work.
    Your formula is 100% accurate.
