Viewing 15 posts - 4,891 through 4,905 (of 6,296 total)
  • in reply to: Unable to retrieve tags (Rockwell) #3563
    Thank you, this is useful info! OPC servers often work with tricks.
    in reply to: arduino #3562
    in reply to: Installation has completed with errors #3561
    What is your default Windows language?
    in reply to: Installation has completed with errors #3560
    Use SetCulture utility to change the application culture to en-GB.
    Also you can click Настройки (5th) then Язык (2nd) and choose English.
    Settings are applied after app restart.
    in reply to: ModDBExport #3554
    Should it say “The channel is not defined” or something so?
    Probably. In the next iteration of development of this module, we will take this into account.
    Thank you, Sabas!
    in reply to: ModDBExport #3553
    That’s funny, but not a bug 🙂
    I will write this behavior in our memories.
    in reply to: ModDBExport to Oracle #3551
    SCADA-Server stores data with milliseconds. You can find screenshots with Oracle DB here in the forum to check it. I think, the problem is in the version of MySQL. Could you try the actual version of MySQL on another PC?
    You don’t need to create an issue on GitHub, because this forum is the primary site for issues.
    • This reply was modified 8 years, 2 months ago by Mikhail.
    in reply to: Source Code KpOpc.dll #3550
    I will recommend OPC UA to our users 🙂
    in reply to: Distinct ports on the same device #3549
    You are welcome )
    in reply to: Installation has completed with errors #3548
    All required files are located in the folders. So you can install services by executeingsvc_install.bat from command line as administrator.
    in reply to: ModDBExport to Oracle #3536
    ScadaServer generated current data with the millisecond of timestamp are all zero.
    What version of MySQL do you use?
    in reply to: ModDBExport to Oracle #3535
    Thank you for the solution. I suppose, that the wrong statement is in the queue and never can be skipped.
    in reply to: ModDBExport #3534
    Do you have an idea in which case a sent value is changed to 0, and in which case it is saved correctly?
    in reply to: Source Code KpOpc.dll #3533
    for the command, you can only make boolean command on/off ?
    Command of the Standard type has a value of double type.
    Binary command allows sending any data.
    in reply to: Modbus Slave mode #3532
    Rapid SCADA works as Modbus master, and it can be TCP server or TCP slave.
    I still can’t open tcp connection with Local tcp port 502, error:The network connection was refused by the server.
    You can use this Hercules utility to test connection.
