1. You need to create commands in the Modbus template.
Test that the commands work well in Communicator.2. Create output channels using Administrator and configure user interface.
In case of follow up questions, please provide screenshots of your settings and communication logs.
MikhailModeratorSound Alarm Module works on SCADA-Server and doen’t relate to the web application.
Also you can replace the default sound file C:\SCADA\ScadaWeb\plugins\Table\sounds\event.mp3
MikhailModeratorPlease find how_to_use.txt in the Linux installation package.
Also Agent is very useful.
MikhailModeratorYou need Webstation 5.0.6.1. See http://doc.rapidscada.net/content/en/version-history/ for the details.
MikhailModeratorPutty and WicCSP utilities help you to work on Linux.
Please ask particular questions to get relevant help.
MikhailModeratorThanks for saying that the issues are solved!
Thanks for this question.
Use this update special for HTTPS.
MikhailModeratorIIS doesn’t work. No reason to reinstall Rapid SCADA.
I can try to fix IIS issue using a remote connection. This is a commercial service.
MikhailModeratorCan you give some template o examples to create a instance in KpOpclogic class?
Could you clarify what example do you need?
MikhailModeratorAm I understand you correcly: When you open this link http://localhost on your server, you get “This site cant be reached”?
You should reinstall Rapid SCADA. This issue relates to IIS.
What OS do you use?
Try this advice.
MikhailModeratorPlease check version of the Webstation app and the version of Chart Pro. What are the both versions?
MikhailModeratorI have no source code of OpcNetApi. Does a decompier, that you use, can create a VS project that can be build for debug?
MikhailModerator🙂
