Change event sound
Forum Home › Forums › Understanding the Software › Change event sound
Viewing 12 posts - 1 through 12 (of 12 total)
  • #4632
    bragofsky
    Hi there, is there any way to change the event sound beep to a different type of sound, a windows sound file for example?
    #4633
    bragofsky
    The idea is to have a louder alarm sound
    #4634
    http://demo.rapidscada.net/plugins/Store/Store.aspx
    Sound Alarm Module The module plays a sound in case of alarm.
    Isn’t that what you need ?
    #4635
    bragofsky
    Hello, this would be great if I manage to get it working. I already install the module and configure a sound file for a input but the browser keeps beeping the same sound. Any thing else i should do?
    Another question, Is there any way to invert the color of “on/off” events? I want ON events as RED and OFF events as green.
    Thanks in advance and congradulations for your software
    Best Regards
    Hugo Braga
    #4636
    Sound Alarm Module works on SCADA-Server and doen’t relate to the web application.
    Also you can replace the default sound file C:\SCADA\ScadaWeb\plugins\Table\sounds\event.mp3
    #4637
    Read this.
    #4638
    bragofsky
    Hello, now i’m confused…. so what’s the propose of the sound alarm module?
    Regards
    #4645
    Sound Alarm Module doesn’t depend on browser. For example, a user close a browser however he can hear alarms. This may be useful for some cases.
    #4666
    bragofsky
    Thanks for your repply,
    Some questions related to webbrowser alarm,
    Is there any way to repeat the sound until event acknolegement?
    I replace the event.mp3 file but the original sound is playing simultanious with the new sound, any way to solve that?
    Regards
    #4672
    This feature requires development of a new plugin which does what you need.
    If you delete the old file, probably it was cached by a browser. Try clearing the browser cache.
    #4868
    bragofsky
    Hello, It worked when cleaning the browser cache.
    Is there any prediction for the plugin development? We apreciate if you do it as a Purchase Module.
    Best Regards
    Hugo Braga
    #4875
    Hi Hugo,
    We can do the required feature for a free. If you interested, write an email that contains detailed requirements. And we would estimate the cost of development.
