Viewing 15 posts - 3,976 through 3,990 (of 6,219 total)
  • in reply to: Download or upload configuration #5886
    The “Default” instance is specified in the Agent configuration. I think, it’s OK.
    I added user ScadaAdmin with password 12345 and application role.
    Did you pass the configuration to the server using the old Administrator?
    Agent looks for the user ScadaAdmin in C:\SCADA\BaseDAT\user.dat
    in reply to: Download or upload configuration #5882
    If this problem occurs during migration, add a user ScadaAdmin with password 12345 to the Users table of the old configuration database.
    Look the error details in C:\SCADA\ScadaAgent\Log\ScadaAgent.log
    This document may help.
    in reply to: Scheme Editor #5877
    In Chrome, press F12, go to the Console tab, and make a screenshot of the error details.
    in reply to: Modbus TCP over GPRS (S27x GPRS RTU) #5876
    Please provide the detailed description of the recent issue.
    in reply to: Sending Email Notifications #5871
    Add a group of contacts in Address book, and then specify the group name in the command text.
    in reply to: Scheme Editor #5870
    in reply to: how can i create my own report like 1 minute report #5865
    If you mean programming, you can use the source code of the minute report as an example. It is available here.
    in reply to: hide the plugins menu in the web #5864
    i hidden the plugins menu by code changed in scadaweb.
    What code did you change? Restore it back if needed.
    in reply to: More about DBExport. #5859
    It is possible to customize data sending to DB
    You can filter data by changing SQL queries in the module settings.
    Note: if you’d like, you can write to the Russian forum. It’s up to you.
    in reply to: More about DBExport. #5857
    What is the trigger of the exporting current data?
    When Communicator sends data to the Server app. It sends the values twice, because it does it after a communication session, and with fixed intervals.
    If you set “Period of sending all device tags” to 0 (in Communication – Common Parameters), you will avoid duplication.
    in reply to: Server Problem #5856
    You’ve provided the local link. Please provide a screenshot.
    in reply to: ASCII text #5846
    This is possible if you split the text into 2 parts. I know this is hard, but currently it works so.
    If you have limited number of phrases to display, use enumerations.
    in reply to: sending only zero command by communicator #5845
    Please try:
    BitConverter.ToDouble(new byte[] { 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00}, 0)
    I don’t test formulas on the forum, because this is a part of Extended Support.
    in reply to: User input through Scheme #5844
    As a recap of the above post, you need to create an input channel, an output channel, and use SetVal(…) for the output channel.
    If you provide screenshot of your configuration database, we can validate it.
    in reply to: Error message in scada server #5843
    In most cases SCADA-Server starts automatically and you don’t need to start it manually. Please watch our videos and do the same.
    How to translate this error?
