sending only zero command by communicator
Forum Home Forums Understanding the Software sending only zero command by communicator
  • #5826
    Avatardineshkumargowd
    Dear Mikhail,
    I have assigned some output coils in the commands, set them as multiple and element count as ” 1 “. When i am trying to send the command 1 to the commands it is just sending ” 0 ” every time.
    Please find the attached image for your reference and kindly do the needful how can i do this..
    Write Coil only zero
    https://drive.google.com/file/d/1CHlKXC_3DvNTu856SLkBpJXZ5wMjgf6M/view?usp=sharing
    #5829
    MikhailMikhail
    To assign multiple coils, you should send a command of binary type and specify a byte array as a command data.
    The command data array contains 00 and 01 as I remember.
    #5830
    MikhailMikhail
    If you send Standard command you can play with a formula of input channel:
    BitConverter.ToDouble(new byte[] { 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00})
    In the formula set the required byte to 1.
    #5832
    Dear Mikhail,
    I didn’t understand about this formula. I have tried this in output channel, but the server is showing error.
    Trailing image for your reference.
    https://drive.google.com/file/d/11-B14xYAftoIb-XwzY10gW925Kxmp1Fz/view?usp=sharing
    Kindly help me how can i convert the standard command to byte.
    #5845
    MikhailMikhail
    Please try:
    BitConverter.ToDouble(new byte[] { 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00}, 0)
    I don’t test formulas on the forum, because this is a part of Extended Support.
