Viewing 15 posts - 3,376 through 3,390 (of 6,218 total)
  • in reply to: Image pack (Meter scheme) object unable to find #7699
    Image pack is just a set of images. You could copy them to any location and use the images when select an image for a component property.
    in reply to: Extra Component – Frame #7698
    I think, you should open in the frame the page with fixed URL that would refresh it’s content automatically.
    in reply to: Extra Component – Frame #7694
    No. URL is fixed in Frame.
    Could you provide an example why do you need this?
    in reply to: Elastic Report Flexibility #7693
    Now I understand what do you need to show in the report.
    Elastic Report doesn’t directly cover this case.
    May be you could print all values from 0:00 to 23:00, and then use Excel formulas (that can be inserted in the report) to calculate the required values.
    in reply to: Windows server 2019 VM server is unvailable #7692
    You should look for additional error info that is written in C:\SCADA\*.log files
    Each Rapid SCADA application has its own log file.
    in reply to: HTTPS endpoint #7686
    1. Download the web.config files and overwrite the existing in C:\SCADA\ScadaWeb\
    2. Enable HTTPS on IIS. Link
    3. Install SSL certificate if you use domain.
    in reply to: Database MySQL usage #7685
    An input channel can store only 8 Latin characters, because channel value size is 8 bytes. SCADA mostly works with numbers than strings.
    in reply to: Integration with IAP #7684
    You should learn the existing source code of the Login.aspx page, understand it, and then implement your own.
    in reply to: Elastic Report Flexibility #7682
    Please provide the report example.
    Elastic Report allows to set a reading hour.
    in reply to: Server is unavailable #7681
    The Agent service doesn’t work. If you need more info, create a new topic.
    in reply to: Website Artical section is down, can’t access dev guides #7673
    Thank you. We will check and fix it.
    in reply to: Automatic Control Module integration #7672
    Just copy the module files into /opt/scada/ScadaServer
    Do you configure Rapid SCADA on RPi4 using Windows?
    in reply to: Send command #7666
    You should try to download and setup the module. If you have questions during this process, please ask.
    in reply to: Send command #7665
    That means Press the Button, the value will be 1, released the Button, past some second, the value auto will be 0. I do likes that, don’t i?
    I also would choose this method.
    When a user click the button, the 1st command is sent. Then you need Automatic Control Module that triggers on the 1st command and automatically sends the 2nd command after the specified delay.
    in reply to: Questions regarding formular #7664
    Messages are sent in UTF8. It’s here. If you provide a particular example, we can check it here.
