Forum Home › Forums › Runtime Bugs › Windows server 2019 VM server is unvailable
- This topic has 8 replies, 2 voices, and was last updated 5 years, 11 months ago by
December 8, 2020 at 9:23 am #7690
mark9966
ParticipantHI,
i’m working with a gcp VM with windows server 2019. Whene i hit public_ip/scada it goes to login page but then “server is unavailable” is presentend after logging in.
https://postimg.cc/zV9JMWpQ this what i have on the instance stats.
What do i need to do? it seems agent it’s not working.
This topic was modified 5 years, 11 months ago by
December 8, 2020 at 3:35 pm #7692
You should look for additional error info that is written in C:\SCADA\*.log files
Each Rapid SCADA application has its own log file.December 9, 2020 at 3:04 pm #7702mark9966
i’ve tried to check all SCADA\*.log for allt the applications but everi Log folder is empty so i don’t know how i get the “server is unavailable” error.
What can i do?
December 9, 2020 at 5:04 pm #7703mark9966
ParticipantInside ScadaWeb log
2020-12-07 12:43:37 <INSTANCE-4><DefaultAppPool><ACT> Initialize common web application data
2020-12-07 12:43:37 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2020-12-07 12:43:38 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
2020-12-07 12:43:38 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
2020-12-07 12:43:38 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
Scada.ScadaException: Unable to receive the configuration database modification time.
at Scada.Client.DataCache.RefreshBaseTables()
2020-12-07 12:43:41 <INSTANCE-4><DefaultAppPool><ACT> User information has been added. IP address: 93.70.86.159. Session: 4tnsyzmb4n05etxvagb2irj0
2020-12-07 12:43:47 <INSTANCE-4><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2020-12-07 12:43:47 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2020-12-07 12:43:47 <INSTANCE-4><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: 93.70.86.159
2020-12-07 12:46:29 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2020-12-07 12:46:30 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
2020-12-07 12:46:30 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
2020-12-07 12:46:30 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2020-12-07 12:46:30 <INSTANCE-4><DefaultAppPool><ACT> User information has been added. IP address: ::1. Session: f0e4iwlzffopurbcu2tt2e15
2020-12-07 12:46:40 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2020-12-07 12:46:41 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
2020-12-07 12:46:41 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
2020-12-07 12:46:41 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2020-12-07 12:46:41 <INSTANCE-4><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2020-12-07 12:46:41 <INSTANCE-4><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: ::1
2020-12-07 13:00:45 <INSTANCE-4><DefaultAppPool><ACT> User information has been removed. IP address: 93.70.86.159. Session: 4tnsyzmb4n05etxvagb2irj0
2020-12-07 13:00:45 <INSTANCE-4><DefaultAppPool><ACT> User information has been removed. IP address: ::1. Session: f0e4iwlzffopurbcu2tt2e15
2020-12-07 13:00:45 <INSTANCE-4><DefaultAppPool><ACT> Application shutdown
2020-12-09 10:24:24 <INSTANCE-4><DefaultAppPool><ACT> Initialize common web application data
2020-12-09 10:24:25 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2020-12-09 10:24:26 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
2020-12-09 10:24:26 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
2020-12-09 10:24:26 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2020-12-09 10:24:27 <INSTANCE-4><DefaultAppPool><ACT> User information has been added. IP address: 93.70.86.159. Session: mk1a2phyybzvrjdegdgh3ct1
2020-12-09 10:24:32 <INSTANCE-4><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2020-12-09 10:24:32 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2020-12-09 10:24:32 <INSTANCE-4><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: 93.70.86.159
2020-12-09 10:46:20 <INSTANCE-4><DefaultAppPool><ACT> User information has been removed. IP address: 93.70.86.159. Session: mk1a2phyybzvrjdegdgh3ct1
2020-12-09 10:46:49 <INSTANCE-4><DefaultAppPool><ACT> Application shutdown
——————————————————————————–December 10, 2020 at 2:02 pm #7706
MikhailModeratorWhat in ScadaServer.log?
You should check that no other application except SCADA-Server uses TCP port 10000.December 11, 2020 at 4:45 pm #7715mark9966
ParticipantI have nothing since it is a new VM on gcp which has installed only rapid scada. I do not have anything on server log except of log in scadaweb tha i showed. What can i do? i tried to reinstall it but it seems not everything runs (at least no agent).
December 13, 2020 at 7:56 am #7720
December 14, 2020 at 2:49 pm #7725mark9966
ParticipantWhat in ScadaServer.log?
I have no log files other than in the ScadaWeb folder, is this possible? all Log folders are empty except for C:\SCADA\ScadaWeb\log and what showed below. What can the problem be?
2020-12-11 16:33:21 <INSTANCE-4><DefaultAppPool><ACT> Initialize common web application data
2020-12-11 16:33:21 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2020-12-11 16:33:22 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
2020-12-11 16:33:22 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
2020-12-11 16:33:22 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2020-12-11 16:33:26 <INSTANCE-4><DefaultAppPool><ACT> User information has been added. IP address: ::1. Session: sd5thkccmsit3analnrcpmym
2020-12-11 16:33:31 <INSTANCE-4><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2020-12-11 16:33:31 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2020-12-11 16:33:31 <INSTANCE-4><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: ::1
2020-12-11 16:35:56 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2020-12-11 16:35:57 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
2020-12-11 16:35:57 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
2020-12-11 16:35:57 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2020-12-11 16:35:57 <INSTANCE-4><DefaultAppPool><ACT> User information has been added. IP address: 127.0.0.1. Session: rvwcnr2dnz133hwtho02dffa
2020-12-11 16:36:03 <INSTANCE-4><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2020-12-11 16:36:03 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2020-12-11 16:36:03 <INSTANCE-4><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: 127.0.0.1
2020-12-11 16:36:28 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2020-12-11 16:36:29 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
2020-12-11 16:36:29 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
2020-12-11 16:36:29 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2020-12-11 16:36:29 <INSTANCE-4><DefaultAppPool><ACT> User information has been added. IP address: 34.122.105.138. Session: fwv13doqtao3s14sq23lwvl0
2020-12-11 16:45:47 <INSTANCE-4><DefaultAppPool><ACT> User information has been removed. IP address: 127.0.0.1. Session: rvwcnr2dnz133hwtho02dffa
2020-12-11 16:45:47 <INSTANCE-4><DefaultAppPool><ACT> User information has been removed. IP address: 34.122.105.138. Session: fwv13doqtao3s14sq23lwvl0
2020-12-11 16:45:47 <INSTANCE-4><DefaultAppPool><ACT> User information has been removed. IP address: ::1. Session: sd5thkccmsit3analnrcpmym
2020-12-11 16:45:47 <INSTANCE-4><DefaultAppPool><ACT> Application shutdown
2020-12-14 14:40:30 <INSTANCE-4><DefaultAppPool><ACT> Initialize common web application data
2020-12-14 14:40:30 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2020-12-14 14:40:31 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
2020-12-14 14:40:31 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
2020-12-14 14:40:31 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2020-12-14 14:40:31 <INSTANCE-4><DefaultAppPool><ACT> User information has been added. IP address: ::1. Session: 2nvstsgnbfhbftscd3dt1f0y
2020-12-14 14:40:40 <INSTANCE-4><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2020-12-14 14:40:41 <INSTANCE-4><DefaultAppPool><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
2020-12-14 14:40:41 <INSTANCE-4><DefaultAppPool><ACT> Disconnect from SCADA-Server
2020-12-14 14:40:41 <INSTANCE-4><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2020-12-14 14:40:41 <INSTANCE-4><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2020-12-14 14:40:41 <INSTANCE-4><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: ::1December 15, 2020 at 12:30 pm #7728
MikhailModeratorCheck the the following Windows services are installed and started
ScadaAgentService
ScadaServerService
ScadaCommService -
