Viewing 15 posts - 1,981 through 1,995 (of 6,288 total)
  • in reply to: Webstation error #12137
    It means that Webstation does not provide its status to Administrator. It’s normal and application specific.
    in reply to: Webstation error #12134
    I can go to webview by lauching of Webstation (in folder of
    and it goes to http://localhost:10008/
    This is a correct URL. See the manual.
    I don’t see the Plugin page?
    Plugin management is moved to the Administrator application in v6.
    in reply to: auto log out of Web SCADA #12128
    Start Internet Information Services (IIS) Manager, select the application pool used for Rapid SCADA, open Advanced Settings of the application pool, and set the following options:
    General – Start Mode: AlwaysRunning
    Process Model – Idle Time-out: 0
    Recycling – Regular Time Interval: 0
    in reply to: Sending email by using Gmail sudden fail #12127
    in reply to: opc ua #12124
    If the both versions are installed in parallel, there will be a conflict, because they use the same TCP ports. It’s better to uninstall the older version first. Or use virtual machines for different versions.
    Please use documentation for version 5. The visual changes are not too big. The most changes were made inside the engine.
    in reply to: cannot find scada communicator #12121
    User interface of Communicator is integrated in the Administrator application.
    ScadaCommCtl.exe is for very old versions.
    in reply to: opc ua #12120
    Yes, Rapid SCADA 5.8.4 includes OPC UA client driver. Configuration of OPC UA driver is similar to OPC Classic driver.
    I suggest Rapid SCADA 6 for new projects, because it is more simple to configure.
    in reply to: OpenPLC Integration #12116
    Hi Mark,
    openPLC supports Modbus communication protocol. So it can be integrated with Rapid SCADA. This article describes how to configure Modbus on Rapid SCADA.
    For new projects I suggest to download Rapid SCADA 6.
    in reply to: Sending email by using Gmail sudden fail #12114
    According to the provided line013.log, Telegram Driver requires a valid registration key.
    in reply to: V6 Captcha on the login screen #12113
    The creation of a generic mechanism should be done by our resources. Plugins can be developed by 3rd parties, by us, or sponsored.
    in reply to: V6 Captcha on the login screen #12112
    On a one hand, the captcha is big, while on the other hand, it’s comfortable readable by humans on computer screens and gadgets. We use only digits to make captcha more international.
    Use Google or Microsoft token to implement 2FA for enhanced login security. Is this possible to be included in the future plan?
    Thank you for this idea. First of all, we should provide a generic mechanism to allow using additional plugins for external auth systems. Then implement such plugins. I’ve added it to the wishlist.
    in reply to: SCADA-related services cannot be automatic started #12111
    If I change the service startup type from automatic to automatic (delayed) startup, the 3 services of rapidSCADA can start normally.
    I don’t know why there is no need to set the delay in win 10 desktop version but it needs to be set in win server 2022.
    do you have encountered such a case before?
    This is a weird thing. Thank you for finding a workaround.
    We haven’t met this before. However, as for me, I haven’t tried Windows Server 2022 yet.
    In case I got new related info, I will text here.
    in reply to: Sending email by using Gmail sudden fail #12104
    Mono 6.12.0.122 is up to date.
    But in the screenshot https://imgbb.su/image/xTz7FM the error is in Mono.Security.dll 4.0.0.0. Could you search for Mono.Security.dll inside subdirectories of /opt/scada ?
    If you found Mono.Security.dll there, delete it and restart the Rapid SCADA services.
    in reply to: How do you create custom scheme editor components? #12099
    Components contain C# and JavaScript code. They are loaded and created by Scheme Editor.
    Source code of scheme components for Rapid SCADA 5 is here.
    If you have certain questions, ask.
    in reply to: SCADA-related services cannot be automatic started #12098
    Thank you for your care.
    According to the messages, Server started successfully when executed manually.
    Could you try executing svc_stop.bat and svc_start.bat from command line as administrator.
    What is written in SCADA\ScadaSever\Log\ScadaServer.log ?
