Viewing 15 posts - 1,936 through 1,950 (of 6,287 total)
  • in reply to: MQTT not reading messages #12260
    You should choose “MQTT Client” for a device, not “MQTT”.
    MQTT Client is the new driver for v6.
    Don’t forget to set Communication Channel = MQTT client in the line options.
    In case of issues, please provide links to screenshots of your settings and errors.
    in reply to: Export data to XML #12258
    And my last question
    Ask as many questions as needed.
    in reply to: Export data to XML #12257
    PostgreSQL is the main DBMS for Rapid SCADA. Therefore, there are special features for this database.
    in reply to: Export data to XML #12256
    You should create your own stored procedures that fill code and name and use them in the Export to DB module. However, it is not optimal.
    In case of using PostgreSQL, you can upload the project to the database, so you can find channel code and name by its ID.
    in reply to: формат float ieee-754? #12255
    This forum is in English. For using Russian, please write on https://forum.rapidscada.ru/
    in reply to: Installation problem RapidScada 5 #12254
    For some reason, the services were not registered in OS. You should register them manually by executing the items 7-9 from the manual.
    in reply to: Elastic Report #12249
    Elastic Report supports multiple sections of the same type in a report.
    You should check the error details in ScadaWeb.log
    I will try to use the available information. If that’s not enough, I’ll ask.
    Next week I will try to reproduce the issue, and write about the results here.
    in reply to: Rapidscada in Debian (on IoT2050) #12244
    The issue is not related to nginx. .NET is not properly installed.
    In the console image, could you switch the second “Console” tab to Console also? And then press F5 to refresh the page and get messages into the console.
    in reply to: Export data to XML #12235
    To export data to MySQL, use the Export DB module, located in Server – Modules.
    I don’t know if MySQL supports XML functions like Postgres.
    Thank you for the report.
    Could you copy here the URLs from the address bar for the both screenshots?
    Press F12 in browser, go to the Console tab, and refresh the web page with incorrect chart. What messages are printed in the console?
    in reply to: Export data to XML #12228
    In Administrator:
    – Open Server – Archives
    – Activate the MinCopy archive and configure its options
    – Install PostgreSQL and create a database rapid_scada with user postgres and password postgres. You can change password in Config\ScadaInstanceConfig.xml
    – Upload the project to run
    in reply to: Custom Page #12225
    Custom web page example for v6 has not been developed. You should use main-api.js to get data from a web page.
