April 26, 2023 at 11:38 am in reply to: Understanding the data exchange between Rapid Scada and MySQL #12497
MikhailModeratorDear Mr. Han,
Please create a new topic to discuss your question, because the current topic is about MySQL data exchange.
Webstation v6 uses .NET6. So an application pool, named “.NET v4.5” is invalid.
The Server service listens to the port 10000, not 80.
May be the module author @jurasskpark can help you.
Also make sure that *.View.dll has been copied to the ScadaAdmin\Lib folder.April 21, 2023 at 5:22 pm in reply to: Time difference between mysql DB and rapid scada server #12485
MikhailModeratorIn log files, the server’s time zone is used.
In the database, timestamps are passed in UTC. However, actual time zone is driver dependent.
In Webstation, time zone is specified by the web app configuration. By default server’s time zone is used. It can be changed in Administrator.April 21, 2023 at 5:08 pm in reply to: Understanding the data exchange between Rapid Scada and MySQL #12484
MikhailModeratorIf the module does not work as expected, check the module log file.
April 21, 2023 at 5:05 pm in reply to: Understanding the data exchange between Rapid Scada and MySQL #12483
If you need to write data to DB on button click, probably, you should try DB Import Driver (instead of DB Export Module). That driver can write data on command.
The driver library is DrvDbImport.dll
MikhailModeratorIf language file cannot be loaded, the error should be written in the log file.
MikhailModeratorWindows Server 2016 is OK.
Please check Webstation log file for errors.
Webstation 5.x is not compatible with Server 6.x and vice versa.April 20, 2023 at 10:50 am in reply to: Time difference between mysql DB and rapid scada server #12473
Access to the links is denied.April 19, 2023 at 12:02 pm in reply to: archived data more the 30days, it cannot be displayed normally #12470
MikhailModeratorThe bug has been fixed. The fix will be included in the next release of the plugin.
MikhailModeratorThe report generates, and I can see data in there… although excel doesn’t open the file.
Open Excel first, then open the file from Excel.
MikhailModeratorI would recommend to upgrade Rapid SCADA to the latest version. Missing phrases are a sign of a problem with the installation.
MikhailModeratorI mean
http://
Using the formula you can send different commands with a button, but it will require 2 clicks. As I understand you correctly, you need to send the 1st command on button down and send the 2nd command on button up. If so, it requires development of a new component. We can do that by a contract. For more details, please email us.
