Communicator 6 can work either as OPC UA client and server.
OPC DA client is available, OPC DA server not supported.
MikhailModeratorIn general, yes.
According to C/C++/C# syntax, the equality operator is==
Also you can check channel status, for example,Stat(1) > 0
MikhailModeratorHello Paulius,
You should create additional channel of the Calculated type to calculate a condition. Then use that channel in the trigger.
According to the condition, the animated GIF can be changed to another image by Dynamic Picture component. But the stop frame will not be restored.
This reply was modified 2 years, 11 months ago by
MikhailModeratorAccording to the history that versions belong to Rapid SCADA earlier than 5.5.1 (March 16, 2018).
How many channels and devices in the project?
Try the Unicode sting data type instead of ASCII.
The images are stored in a scheme file. They are not loaded from some directory.
There is no a component to display a sequence of images. A possible method is using animated GIFs.
MikhailModeratorWhat application has a version 5.0.3.0?
This manual may help.
Can I find the old program version I used so far somewhere that I can at least restore the old state on the new server?
The oldest version that can be downloaded is 5.8.4.
You could simply copy C:\SCADA folder to a new server and register services as described in manual installation article.
MikhailModeratorSetting channel value doesn’t cause sending a command. Therefore the module is needed.
MikhailModerator🙂
You could try creating animated GIFs and using them inside Dynamic Picture components.
The above links don’t work.
June 19, 2023 at 10:24 am in reply to: Is it possible to display the hexadecimal characters of the input value? #12827 -
