Viewing 15 posts - 1,561 through 1,575 (of 6,268 total)
  • in reply to: incorrect transaction ID #13224
    ScadaClient is class is not thread safe, while you execute client.GetCurrentData in many threads.
    in reply to: New release Rapid SCADA 6.1.x #13221
    Old versions are not published. I suggest to upgrade to the latest version.
    If you need to move the software to another server without any changes, copy files and use this instruction.
    in reply to: Webstation errors #13219
    Make sure that you don’t ignore registration keys when upload the configuration. The checkbox must not be set.
    https://ibb.co/RT4kMz6
    in reply to: add new condition ins scada scheme V5 #13217
    Please provide more info related to the question.
    in reply to: Webstation errors #13216
    Open the file C:\SCADA613\ScadaAgent\Config\ScadaAgentConfig.xml and check the Directory parameter. In your case, it should be C:\SCADA613\
    After change ScadaAgentConfig.xml, restart the ScadaAgent6 service.
    in reply to: Add new conditions #13205
    I want these to work well with all of Rapid SCADA’s components and possibly other components plugins .
    It would be nice.
    Could you advise on whether I should integrate these directly or if there’s an existing model I should follow?
    Internal editor mechanism should be significantly updated to support such feature. The question is quite abstract.
    in reply to: chart plugin within same tab #13203
    We use bootstrap for displaying popups. That popups have adaptive width. We should experiment with height.
    • This reply was modified 2 years, 10 months ago by Mikhail.
    in reply to: Scada Scheme Editor without Admin #13202
    Scheme Editor is a Windows application that interacts with a web page. Administrator permissions are required to open TCP port, so web page can get and send data to the application.
    in reply to: Grafana Integration on RapidScada 6 #13197
    Is it possible to simply link Rapid Scada 6 to Influx DB Cloud?
    Yes, it’s possible. Take into account that a free Influx DB cloud tier is very limited.
    in reply to: Remote commumicator #13195
    Try asking the author, @jurasskpark, on this forum or GitHub.
    in reply to: connect to microsoft SQL #13194
    Please provide screenshots.
    in reply to: scadaadmin6.1 under wine produce difference token? #13185
    Thank you for the info.
    in reply to: Host can’t be null , Normal execution is impossible. #13184
    You should update ScadaInstanceConfig.xml
    It was changed in the recent versions.
    in reply to: Remote commumicator #13183
    DB Import Plus includes additional features described in the driver docs. I haven’t tried this module by myself.
    in reply to: New release Rapid SCADA 6.1.x #13175
    Rapid SCADA 6.1.4 has been released. The changes mainly affected the web application and plugins.
    Added new plugins:
    – Store Plugin (included by default)
    Map Plugin: user can switch layers, plugin displays moving objects, marker labels and geometric shapes, supports custom marker icons.
    Thus, the work on porting modules to version 6 has been completed. The update is recommended for installation.
